586,052 active members*
4,190 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Changing Dimensions in a file
Results 1 to 3 of 3
    Jun 2020
    I am not proficient in Alphacam, I have some pre-set files we use on the regular. We'd like to modify some dimensions (keep overall design just change dimensions in the geometry) is there an easy tutorial that is free out there? I really don't know how to change the dimensions (there is no easy description of the icons and buttons). We are running version 2020.1
    Thanks in advance!
    Sep 2007
    8
    Re: Changing Dimensions in a file
    Under the edit folder in your ribbon is the scale command
    Scott
    Dec 2005
    68
    under geometry tab select edit list geometry , you can choose the geometry point to change
  1. changing text colour in dimensions
    By Lafaso870 in forum Uncategorised CAD Discussion
    Last Post: 12-01-2010, 03:31 PM
  2. Changing File Names
    By TeeGate in forum Mastercam
    Last Post: 05-18-2010, 09:49 PM
  3. changing the std file
    By riverracer in forum Haas Visual Quick Code
    Last Post: 04-25-2009, 08:29 AM
  4. Replies: 7
    Last Post: 10-22-2008, 02:38 AM
  5. Changing file names
    By CNCMike in forum Solidworks
    Last Post: 08-13-2008, 02:44 PM
