586,077 active members*
3,924 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > [BUG] TNGv2 can't enter , in MDI window
    Jun 2017
    143
    I was doing a bit of script work today and went to test a command in the MDI windows which contained a comma:
    (PRINT,[MIN[#<_SPINDLESPEED>,100]])
    but I can't. Every time I hit the comma on the keyboard I get a full stop! I also can't paste anything in with a comma, it gets replaced with a full stop. I tried it on 2 computers and get the same result.
    Cheers
    Simon
    Apr 2013
    110
    Re: [BUG] TNGv2 can't enter , in MDI window
    it's curious. I have tried it too; if I type comma it is written point, if I copy comma it is written point if I copy an entire command as you posted you the commas are interpreted correctly.
    Mar 2017
    1312
    Unless MDI command is a comment, all commas are "converted" to points.
    Half of the world uses comma as a decimal separator and not dot.
  1. TNGv2 for Mac OSX
    By tantemay in forum PlanetCNC
    Last Post: 08-24-2023, 07:12 PM
  2. TNGv2 and G64
    Last Post: 05-25-2020, 07:07 PM
  3. Replies: 1
    Last Post: 05-14-2020, 04:21 PM
  4. TNGv2 Possible bug with (array)
    By theRat in forum PlanetCNC
    Last Post: 02-14-2020, 01:51 PM
  5. [TNGv2 - API]
    By PlanetCNC in forum PlanetCNC
    Last Post: 10-27-2019, 11:23 PM
