586,036 active members*
3,761 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Rapid Rate dsp controller
    Feb 2020
    hallo guys ,
    i have CNC machine with DSP controller , i already set g codes reading from software (i use aspire) everything works fine .
    i cant find how i can change speed between cuts (from one to another travel speed) i change it in software (rapid rate)but nothing happens , it goes very slow from one cut to another....
    Re: Rapid Rate dsp controller
    USA Client Teach You Use DSP Handhold Cnc Control System
    https://youtu.be/D7x6Bh86JKE
    Cnc router new user learning DSP in Omni factory
    https://youtu.be/q3mJeQBnp4I
    If your control system is A1X,you can follow this friend,hope it could be helpfull for you
    Machine parameter-maximum speed setting: This parameter is the maximum setting of processing speed, does not affect the speed of manual movement XYZ
    After selecting the target processing file and pressing the "OK" key, the user can modify the processing parameters, including processing speed, dry running speed, speed override, and knife drop override. According to your description, the empty line speed setting is too low, resulting in a slow movement from one cutting pattern to another cutting pattern. You can modify the processing parameters before processing
    In the process of processing, you can control the magnification change of the processing speed by pressing "Y+" "Y-", the magnification change is between 0-1, and the magnification change is 0.1 each time
  1. Rapid and feed rate overide
    By fomaz in forum Fanuc
    Last Post: 09-25-2023, 01:12 AM
  2. O mate M slow rapid rate
    By diemaker in forum Fanuc
    Last Post: 10-06-2013, 08:04 PM
  3. Fanuc 21-M rapid rate
    By Jdavis733 in forum Fanuc
    Last Post: 02-12-2011, 10:37 AM
  4. Rapid feed rate with mach3
    By kweierbach in forum Benchtop Machines
    Last Post: 06-24-2009, 06:31 PM
  5. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
