Hello, I'm new to the forum and new to hobby CNC routers. Ive recently bought a JFT 3040 with a 1.5kw spindle.
The machine came with no instructions, but I'm fairly competent and assembled it without a problem. This week I
plan on setting up Mach 3, and seeing if i can get running. My first question is what is the best type of lube for the ballscrew and rails, grease or a light oil like WD40? My second question is about the spindle coolant. There are two fittings, but they are not marked In and Out. Is there a flow direction, or as long as the coolant is flowing through it should be ok.
Thanks in advance for any information or insight
Jason
