586,103 active members*
3,309 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Set Sequence Number as a variable
Results 1 to 17 of 17
    May 2018
    74
    Hello All,I want to know that are we able to set a sequence number as a variable?Let say I want to jump to a block number N1001 and can I do this:BLN = 1001Goto N[BLN] ??Any ideas?Thanks
    Jun 2015
    4154
    Re: Set Sequence Number as a variable
    hy nodo it would be nice if it would work, but it doesn't, so you will need to write explicetly each condition
    Code:
         2m
      < -- 1.5m, eat disinfectants ( bio ) -->
    do you wish to stack many "if's" ? i was also looking for this a while ago, when i needed to group 10-15 conditions, but in the end i wrote them one by one
    if i may, what do you wish to do ? if you wish, i may help you with code layout / kindly
    ps : a little more infos : N O V are not modal ... they can not be used before (nor after) "=" ... however, if you use numbers after them ( at least N O if i remember corectly), then you may read those numbers using system variables, but so far i never encountered a case that would require such a trick ( like reading active adress or subprogram )
    Jun 2015
    4154
    hello, here are 2 examples for staking " if's " :
    Code:
        IF  [  condition a  ]  NA
        IF  [  condition b  ]  NB
        IF  [  condition c  ]  NC
        IF  [  condition d  ]  ND
        NA   action a
                       goto NZ
        NB   action b
                       goto NZ
        NC   action c
                       goto NZ
        ND   action d
                            NZ noex
    Code:
           IF  [  not condition a  ]  NB
                       action  a
           goto NZ
       NB  IF  [  not condition b  ]  NC
                       action  b
           goto NZ
       NC  IF  [  not condition c  ]  ND
                       action  c
           goto NZ
       ND  IF  [  not condition d  ]  NZ
                       action  d
       NZ noex
    N O V are not modal
    i did not mean modal, i also don't know the word ... i mean those are not read/write, can't be used in math expressions ( N= O= V= are not allowed ) / kindly
    May 2018
    74
    Hi Deadlykitten,Thanks for your info. Actually, I don't need to stack many "ifs". I have a sub program to calculate things for the job. After finish the calculation it will go to destination where we need. So I can call the sub wherever, whenever I want and just assign a block number.Main Programblah blah...BLN = 1001Call O0100My sub looks like this:O0100.....Goto N[BLN]RTSI tried N[BLN] but it did not work. It would be easy and simple if I could set a block number as a variable, right?
    Apr 2009
    1262
    Block numbers as variables is not a standard feature. I've heard that it may be available as an option. Check your Management Data card from the back of the machine to see if it is listed. Check with Okuma to see if it is offered. Definitely not standard though.
    Best regards,
    Jun 2015
    4154
    hy nodo i believed that you wish to stack 'ifs', but i was wrong ...
    CALL O0100 BLN = 1001 ( you may put BLN on same line with CALL statement )
    what do you mean by assigning a block number to a soubroutine ?
    i have no clue what you wish to do, so i can't help ... please be a bit more specific, maybe share your code
    i don't know what you are after, maybe there is a simpler solution / kindly
    Sep 2015
    26
    look into "User Task 3", it lets you do that. We use it in are programming now.
    May 2018
    74
    Quote Originally Posted by rdhoggattjr View Post
    You meant User Task 3 for OKUMA?
    Sep 2015
    26
    Quote Originally Posted by nodochau View Post
    Yeah.
    Code:
    OTDBJ (START TOOL DATABASE FILE LOADER)
    GOTO PAT
    N1 FOPENA MD1:T001.TDB
    GOTO NRTS
    N2 FOPENA MD1:T002.TDB
    GOTO NRTS
    N3 FOPENA MD1:T003.TDB
    GOTO NRTS
    N4 FOPENA MD1:T004.TDB
    GOTO NRTS
    NRTS RTS
    We use this on our Okuma HMC's to retrieve information about the current tool. You just pass the tool number (PAT) and it goes to that N number.
    Aug 2011
    419
    interesting
    Yeah.
    Code:
    GOTO PAT
    GOTO NRTS
    GOTO NRTS
    GOTO NRTS
    GOTO NRTS
    NRTS RTS
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    hy nodo just in case : ut3 is a special function ( at least for mills ), about some extra macro functions, like GOTO [ argument ], IF and WHILE-DO; pls find attached pdf
    Quote Originally Posted by kurmay View Post
    interesting
    MN_^J<DAK?;BGL1345TU@C2=HI confused ...
    hy rdhog ... i was wondering about a relevant code example, and when i saw your post ( which is kind of simple but complex ) i remembered that we talked before about those vs* variables
    you use that modified oo30 or something, that has some multilevels
    i like that code ... i can write it without ut3, using a macro in-file search ... however
    i want to ask you something : that code is executed inside the main program as a part of the tool change code, or it is executed only once, before running the main program ( kind of a tool register / preseter program ) ? kindly
    May 2018
    74
    Hi rdhoggattj,So PAT has to be a tool number or can be a block number?If I set PAT = 01 it will GOTO N1?And If I set PAT = 9001 and it will GOTO N9001 block number?What control are you using?Thanks a lot.
    Yeah.
    Code:
    OTDBJ (START TOOL DATABASE FILE LOADER)GOTO PATN1 FOPENA MD1:T001.TDBGOTO NRTSN2 FOPENA MD1:T002.TDBGOTO NRTSN3 FOPENA MD1:T003.TDBGOTO NRTSN4 FOPENA MD1:T004.TDBGOTO NRTSNRTS RTS
    Aug 2011
    419
    If anyone wants to enable user task 3 function on the cnc machine, he can send me a private message.
    I will not get paid from the first 3 people.
    Sep 2015
    26
    Yes that is correct, but that was just how we use it for tools, it can be used with anything. IIRC I also use it for per program tool and home offsets on our Fastems system. We use P200M and P300M.
    May 2018
    74
    Hi rdhoggattj,It does not work for me. Maybe our machine are old . I did try it but I got error so I posted the issue here though.
    Apr 2009
    1262
    Check to see if User Task 3 is listed on your data Management card and if it is checked or not. If not, then you will have to either see Kurmay ;-) or your local Okuma Rep for the option.
    BTW Kurmay...how do you accomplish such a sacred task??
    Hi sir , plz guide me how to activate User Task 3 for OSP p 200m & p300
  1. Xilog 3 error CN25 : unknown sub-program or sequence number
    By Japie77 in forum CNC Machining Centers
    Last Post: 06-16-2017, 02:28 AM
  2. Serial number in variable?
    By ghyman in forum Haas Mills
    Last Post: 08-30-2016, 11:42 PM
  3. POST 2 SEQUENCE NUMBER ON THE SAME LINE
    By MAINVIST in forum Post Processors for MC
    Last Post: 11-06-2013, 10:31 AM
  4. Sequence number not found
    By Darth Yoda in forum G-Code Programing
    Last Post: 03-09-2013, 08:09 AM
  5. Sequence Number Before Every Tool Change
    By seattle77 in forum Post Processors for MC
    Last Post: 07-16-2009, 03:28 PM
