586,036 active members*
4,224 visitors online*
    May 2020
    8
    TNC 155 RS 232 parameters
    I have a TNC 155 which I have just repaired it and now I have to put the parameters. I have all the parameters except these that configure the RS232 port.
    I use TNCserver for transferring the files. I use the TNCserver in mode ME send only and before it worked perfect but I do not remember the MP
    Now I have put:
    MP71: 515
    MP218: 17736
    MP219: 16712
    MP220: 279
    MP221: 5382
    MP222: 168
    MP223: 1 I tried also 0 with no sucess
    MP224: 4
    But these parameters do not work it says that the IN OUT device is not ready. Everything work perfect except that I cannot upload the programs.
    Any idea what to change?
    Aug 2009
    1573
    Re: TNC 155 RS 232 parameters
    ...this Thread might help ya.
    https://www.cnczone.com/forums/machi...-software.html
    Good luck on your mission,
    DJ
    May 2020
    8
    I tried already all the mentioned solutions, zero results now it has new problem. When I connect the cable the TNC server software freeze and writes that is receiving data but this is not truth. when I disconnect the cable then the software respond again. I should mention also that I installed now a second control and again I have the same issue with the RS232. Is there any possibility the new control to need another cable connections from the previous? Could it be hardware problem? The machine works fine with the new control only the RS232 has problem. I tried all the solutions and parameters that I found on internet with no success. If the problem is the parameters then most probably I put something wrong so I need an advise from someone who has solved this problem in the past or from someone who know about TNC 155Q parameters. Any help is useful. Now I insert the programs by hand but it's not easy for big programs.
  1. Replies: 3
    Last Post: 10-22-2020, 09:20 PM
  2. Parameters
    By drdos in forum Fanuc
    Last Post: 08-16-2013, 07:13 PM
  3. Need help with PMC parameters
    By WCC123 in forum Fanuc
    Last Post: 06-28-2013, 02:02 PM
  4. 3TC Parameters ????
    By nelZ in forum Fanuc
    Last Post: 03-22-2013, 02:14 PM
  5. Parameters 281 and 282 on 0T
    By guhl in forum Fanuc
    Last Post: 10-25-2009, 08:03 PM
