586,112 active members*
3,054 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > MOSFET replacements for DM860H stepper drivers.
    Dec 2012
    192
    Hello everyone.
    Anyone out there knows what MOSFETS are used in the DM860H stepper drivers? Any suggestion for possible replacements?
    Thanks.
    Jul 2014
    13
    Re: MOSFET replacements for DM860H stepper drivers.
    I had an ma860h fail earliert his year and i got it running by replacing all the mosfets with irf640z . i think it might have had irf540s originally but i only had the 640s on hand and it got it working again. I replaced all 8 mosfets to be safe even though only 2 failed
    Dec 2012
    192
    Quote Originally Posted by Zvonkorp View Post
    I apologize for not replying sooner but I was required to do some fieldwork.
    I thank you for your interest. I finally found the parts and the drive is up and running. Fortunately the damage was restricted to the output transistors.
    I do agree with your suggestion of replacing the whole set, that is the 8 MOSFETS. That´s far better than risking another costly machine timedown.
    Thanks again.
    Regards.
  1. Slo-Syn Stepper Replacements : Need Advice From Pros :)
    By ultrahive in forum Stepper Motors / Drives
    Last Post: 06-02-2011, 02:45 AM
  2. Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver?
    By joprinz in forum CNC Machine Related Electronics
    Last Post: 04-28-2011, 09:57 AM
  3. Taig slowed up after stepper replacements
    By Dodad in forum Taig Mills / Lathes
    Last Post: 10-09-2007, 04:49 AM
  4. Good source for motor replacements of Series I stepper motors?
    By Mr. Technical in forum Bridgeport / Hardinge Mills
    Last Post: 07-27-2007, 04:16 PM
  5. MOSFET Gate Voltage and Stepper Circuit
    By atomgonuclear in forum Stepper Motors / Drives
    Last Post: 03-30-2007, 01:17 PM
