586,058 active members*
3,586 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Setting part zero in center of round parts.
    Nov 2017
    13
    I'm fairly new with CNC and curious as to any tricks others have to setting part zero in a round part. On my Bridgeport mill I could find an edge and set zero and then find the other side and had a button on the DRO to divide that new number in half and then set it as zero. Then repeat the process for the other axis. I find I have to do a lot of external calculations to do the same things on my Ultimax control.
    Jun 2003
    205
    Re: Setting part zero in center of round parts.
    I would say the most common method would be to mount a dial / coaxial indicator in the spindle ... in a collet ... clamped to a tool holder ... whatever ... and sweep the round part.
    Like this : https://www.youtube.com/watch?v=X-6v_EkUwt8
    Check out our Real World Machine Shop software at Kentech Inc. - Creators of Kipware® Real World Machine Shop Software | Kentech Inc.
    Jan 2013
    630
    Depends on how much precision you need. I have better results when flipping parts swinging and centering via an indicator. I have a 3d taster but my results of hitting concentricity on a flipped round part for the second OP has been less than stellar with it.
  1. 4th axis on none round part
    By dfearnow in forum Mastercam
    Last Post: 06-27-2012, 04:14 PM
  2. Round Part Workholding in Mill
    By dksoba in forum Uncategorised MetalWorking Machines
    Last Post: 09-21-2010, 01:30 AM
  3. Need to round over the top on a part Help.
    By Cartierusm in forum Rhino 3D
    Last Post: 08-04-2009, 04:48 AM
  4. Fixture for holding 31/32 Round Part
    By Smackre in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-03-2007, 02:24 PM
  5. RFQ- small little round part needed
    By fastolds in forum Employment Opportunity
    Last Post: 12-07-2005, 02:04 PM
