586,096 active members*
3,014 visitors online*
    Feb 2013
    81
    Helix toolpath and Mach 3 issue
    I wonder if someone might be able to assist.
    I have 20 furniture legs to make. They are truncated cones 50mm one end 30mm the other, they are 300mm long.
    I’m used to cnc milling so have set up a RhinoCAM tool path to do a continuos helix cut on my 4th axis from 50 to 30mm over the 300mm length.
    I ran a trial of the job and could see in principal it would work but as I need to do 20 I need the tool tip to return to zero to start a new cycle with a new piece of dowel. I used Mach 3 controller but If I press GOTO ZERO the program attempts to cycle back through the complete spiral NOT an issue i've seen before. What I want it to do is lift above the job and go to zero whilst crucially resetting itself back to 0,0,0,0 for the next run to start.
    Is there additional code I should add in the RhinoCAM mach 3 post processor or will I come across this issue with all Helix tool paths? Where should I look first to correct?
    Jan 2018
    1516
    Re: Helix toolpath and Mach 3 issue
    Quote Originally Posted by marbles View Post
    How does your cam program post the job?
    All my gcodes on my mill have a Z move at the end of the program to lift Z axis out of the way first before the program ends.
    Then moves X,Y to 0 ready for next such as:
    (A sample of one of mine)
    (2. 3MM SLOTS)
    (0 POINT BOTTM RIGHT Z=0)
    (T5 D=3. CR=0. - ZMIN=-12.65 - FLAT END MILL)
    G90 G94 G91.1 G40 G49 G17
    G21
    G0 Z30.
    G90
    (SLOT2)
    M5
    M9
    T5 M6
    S2500 M3
    G54
    M8
    G0 X-171.56 Y128.525
    G43 Z15. H5
    Z4.
    G1 Z1.. F300.
    Y111.275 Z0.5............
    JOB RUNNING
    ...............Y111.275 Z-12.65
    Y128.525
    G0 Z15.
    M9
    G0 Z100.
    G0 X0. Y0.
    M30
    So it runs this slot program then at the end it puts Z to 100. and X,Y to 0.
    Then I load in another piece and run again. So on and so on.
    Feb 2013
    81
    Very helpful thanks!! I'll run a variation of that to see how it works.
    In the meantime I worked out when the toolpath finishes if I Zero Out on the the A axis (4th) and then press Go To Zero it returns to job start super fast without spiralling backwards forever
  1. AXYZ ToolPath issue
    By VTX1800 in forum Commercial CNC Wood Routers
    Last Post: 08-28-2018, 07:18 PM
  2. Need help- Artcam Rotary toolpath issue
    By loyedp in forum Autodesk CAM
    Last Post: 01-03-2018, 07:02 AM
  3. CamBam toolpath generation issue
    By ctilley79 in forum CamBam
    Last Post: 01-29-2013, 05:26 AM
  4. Toolpath issue
    By rewster in forum CamBam
    Last Post: 10-28-2011, 12:53 AM
  5. 2d random toolpath issue
    By rich_cree in forum Vectric
    Last Post: 07-24-2009, 12:35 AM
