586,061 active members*
4,361 visitors online*
Thread: Fanuc 21i TB
    Sep 2005
    273
    Fanuc 21i TB
    Hello all, machine is a doosan puma 700 m with fanuc 21i TB, problem is after setting the Q-setter (re-calibrate) it wont pick up the wear offsets ? re-touched off using the geometry set off the part (no Q-setter) and it worked fine? anybody no what parameter 5020 (ofs no) is used for? thanks
    May 2016
    526
    Re: Fanuc 21i TB
    What do you mean it won't pick up the wear offset
    Sep 2005
    273
    Re: Fanuc 21i TB
    Hi mb, the machine does not read the wear offset, it does not adjust to it
    Sep 2005
    273
    Re: Fanuc 21i TB
    Shut the Machine all the way down and now it works fine
  1. Fanuc tape cut mate fanuc om paramter setting for cutting materials
    By Vijay040engg in forum EDM Discussion General Topics
    Last Post: 08-27-2019, 10:00 AM
  2. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  3. Replies: 12
    Last Post: 12-26-2016, 10:31 PM
  4. Replies: 8
    Last Post: 09-25-2014, 02:58 PM
  5. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
