586,094 active members*
3,921 visitors online*
    Mar 2012
    378
    Hardinge HLV-H Conversion
    I have been wanting to do a CNC lathe conversion for a long time. I have not converted my Jet 13X40 because I still use it manual a lot and I don't want to retract from its ease of manual use.
    I have an opportunity to get a Hardinge HLV-H at a very good price and I am thinking of converting it to a gang tool CNC lathe by taking off the existing cross slide and putting on a long slide for gang tooling with linear rails and a ball screw. The lathe already has a collet closer that would be easy to mount an air cylinder for auto closing and I could add a bar puller. I would either put an encoder on the spindle and use a VFD on the motor or maybe even replace the motor with a big servo so I could add live tooling and index the head.
    I think this would make a very nice CNC since it is a very precision spindle, has the collet closer, is already set up for flood coolant, and it is just the right size for what I need. I am a bit hesitant though about taking a very nice precision manual lathe and removing a lot of great manual features though. A Tormach Slant Pro would suit me fine if I could sell the Hardinge for enough to get one. I see the Hardinge lathes listed for sale for a lot of money, but I don't know that any sell at that price.
    Opinions?
    Dec 2013
    5717
    Re: Hardinge HLV-H Conversion
    I would convert the Jet. You can keep all of the manual functions intact and add CNC to it. I guess you could do the same thing to a HLV-H, keeping all of the manual functionality. It doesn't have to be either or, it can be both with nearly instant change over. I was going to do that to my 13x40 Jet before I bought my slant bed CNC.
    Jim Dawson
    Sandy, Oregon, USA
  1. Hardinge CHNC conversion
    By N4NV in forum South Bend Machinery
    Last Post: 10-17-2023, 03:16 AM
  2. Hardinge Dv-59 cnc conversion
    By minichopper6hp in forum Vertical Mill, Lathe Project Log
    Last Post: 01-08-2018, 04:15 AM
  3. Hardinge CHNC II SP Conversion to Mach 3 Step by Step
    By mike^3 in forum Vertical Mill, Lathe Project Log
    Last Post: 05-02-2014, 11:38 AM
  4. Schaublin/Hardinge CNC conversion?
    By shorton in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2014, 05:23 AM
  5. new CNC conversion - old Hardinge lathe
    By jerry426 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-09-2011, 06:30 AM
