586,106 active members*
2,935 visitors online*
    Feb 2005
    117
    Older C11G Breakout Board Compatable with VFD
    I have an older board in our router.
    The board has no revision numbers on it so I assume it is one of the first. No problems.
    Can I use the board with your 3 HP VFD (sku: VFD22) ?
    Also on your site you have a series of sample wiring diagrams to choose from.
    Anyone in particular to choose ?
    Thank you
    JohnD
    Re: Older C11G Breakout Board Compatable with VFD
    Here is what I remember:
    - It works with a step pin and a 25khz frequency on pin 8 will give you full speed. Not PWM like on current models.
    - I think the relays are controlled by pin 1 and 9.
    - You can use the information on the C6 board to configure the spindle, but using the correct pins.
    Arturo Duncan
    https://cnc4pc.com
  1. Replies: 16
    Last Post: 03-01-2022, 12:26 AM
  2. C11G CNC Breakout Board cnc4pc
    By linx310 in forum For Sale Only
    Last Post: 12-21-2014, 09:07 PM
  3. Replies: 8
    Last Post: 07-31-2012, 12:47 AM
  4. CNC4PC C11G BOARD
    By MegaMoog in forum Benchtop Machines
    Last Post: 05-05-2010, 09:29 PM
  5. KL-B25 or C11g Breakout board?
    By technosteve in forum Automation Technology Products
    Last Post: 03-14-2009, 01:32 AM
