586,377 active members*
2,513 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Cutting of PCB tracks
Results 1 to 5 of 5
    Feb 2018
    7
    Hello All
    Hope you all out there are keeping well and safe.
    I have many things on the go at this moment it time with my Micro CNC Mill, run with Mach 3. And tinker with small hand built electronic projects. I would like to bring these two together and cut out my own PCB tracks and hole layouts on copper clad boards. Can any recommend some simple free software to make up tracks and hole patterns then convert them to G Code to then port it over to the Mill to cut the holes and tracks. If possible the software has to run offline as the area in which my ManCave is located is in the dead zone as far as internet connection goes. Any suggestions will be most helpful.
    Paul
    Nov 2013
    4395
    Re: Cutting of PCB tracks
    I use Eagle (free Demo version) to design the boards, it has a free ULP called PCB-to-Gcode that generates Gcode from
    the artwork and then I use Autoleveller to tweak the Gcode to accomodate any minor twist or bow in the PCB blank.
    I've been doing this for six years and for the last year almost daily.
    I have investigated Kicad (open source) and Flatcam (free) but have yet to make the switch, both seem good, I just have that
    much 'momentum' with Eagle and pcb-gcode.
    Craig
    Nov 2012
    1267
    My workflow is:
    - FreePCB (to design the board and make Gerber files)
    - CamBam (to make G-code)
    - Autoleveller (to adjust the G-code for height variations)
    FreePCB and Autoleveller are free. CamBam is a paid program with generous trial terms.
    Nov 2012
    154
    I tend to use KiCAD for designing the PBC then (my own) GCAM SE to convert the Gerber files to G-code I can mill. One of these days I really ought to figure out auto-leveling too but I'm not quite there yet.
    Quote Originally Posted by PKCNC View Post
    Hello All
    Paul
    CircuitCAM is often used here.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. moving gantry , where to put the tracks
    By stragenmitsuko in forum DIY CNC Router Table Machines
    Last Post: 11-30-2014, 05:50 PM
  2. Some tracks wider, some tracks thiner
    By dmha in forum PCB milling
    Last Post: 10-30-2014, 08:03 PM
  3. Spoilboard Surface with T-Tracks
    By tangeray in forum DIY CNC Router Table Machines
    Last Post: 05-13-2013, 01:05 AM
  4. Laying down tracks
    By cncadmin in forum EnRoute
    Last Post: 09-11-2012, 04:50 AM
  5. Sliding door tracks and rollers
    By Apples in forum Waterjet General Topics
    Last Post: 06-11-2004, 01:34 AM
