586,089 active members*
3,893 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > CL-200 meldas 64 msc-803 reinitialize control
    Feb 2020
    Good afternoon, I'm having troubles with reloading parameters back in after battery loss. The problem is that I didn't have reliable copies of my all1 all2 and all3 backup files. I've got original factory parameters from Mori, however once I load them and set x and z zero points I can move the axis, and index the turret, clamp and unclamp the Chuck but I cannot make any MDI commands, it won't insert them, and it shows I have no available space for programs. I'm not really familiar with the control, but I've learned a lot over this ordeal. Any help in the right direction would be much appreciated.
    Aug 2005
    82
    How is you machine recently.
    Hope it stay in working condittion.
  1. help.,,,, how to reinitialize M32B
    By mantenim in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-06-2014, 12:23 AM
  2. meldas 520 control
    By Bada Bing in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-29-2013, 06:58 PM
  3. mazak t32-2 lathe scared to reinitialize.
    By neigh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-03-2011, 02:40 AM
  4. Meldas 300 Control
    By camtd in forum Parametric Programing
    Last Post: 02-26-2011, 12:19 AM
  5. Fanuc 6T. How to reinitialize the memory
    By starn36 in forum Fanuc
    Last Post: 02-26-2009, 01:20 AM
