I am profiling a curve but the rapid height is way too high and doesn't correspond to my SafeClearance setting. Is there something else I should check? The clearance heights for other operations (z-level, planar) are fine and what I would expect.
I too occasionally have this problem and regenerate once it twice usually fixes it, though it is inconvenient when you only realise it after when you go to run the part.
Sent from my Pixel 3 using Tapatalk
Regenerating multiple times didn't work for me. This also happens on a trivial test part.
