586,071 active members*
3,987 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Alphacam Lathe face groove
    Dec 2005
    68
    I have alphacam 2021 , i need to make a face groove in 14 degrees angle and i have 2 issues
    1- the tool is 14 degrees tilt so i need to get the tool path 14 deg. to avoid crash
    2- the program does not take in consideration the material removed from the front of the part and until reaches the grove face material (.700 deep ) is cutting air
    the part has a step of .700 deep and on the face of that step is the groove located
    Dec 2005
    68
    Re: Alphacam Lathe face groove
    As far as i can find out according to the technical service support there is no way to do the groove at an angle , i have a part with a grove on a 45 degree and this program can't make it hope they can fix that
    On Mastercam you can select the angle of the tool path , i was told alphacam is one of the best and i have my doubts
  1. alphacam face milling m12
    By basswakr in forum Alphacam
    Last Post: 11-28-2018, 09:10 PM
  2. Haas tl-2 profile face groove
    By Trex90 in forum Haas Lathes
    Last Post: 06-20-2012, 01:53 AM
  3. FACE GROOVE
    By nascad in forum Uncategorised MetalWorking Machines
    Last Post: 10-11-2009, 06:42 PM
  4. Small Face Groove Cutting
    By TomL21 in forum MetalWork Discussion
    Last Post: 07-29-2009, 11:40 PM
  5. .0625 face groove
    By bowhunter in forum MetalWork Discussion
    Last Post: 08-08-2007, 12:51 PM
