586,036 active members*
3,695 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > DesignEdge cutting length measurements off
    Jun 2020
    Has anyone had problems with the machine not cutting the correct size of material as what is shown on their computer. Everything is currently cutting short on the length side of the table(x axis) but the width (y axis) side is perfect. About every 12” the machine is off .75” short. I have picture of my setting and the measurements of what I want it to cut to what it actually cut.
    Attached Thumbnails Attached Thumbnails 053B4706-F5DB-470B-80AE-E78C9B9883B5.jpeg   DBE709C5-1B46-4E20-BFA0-E59BA2642F9F.jpeg   13776B8D-4E1B-4BF0-9E41-B1C12A1343F7.jpeg   5A2DAB0F-68DA-4003-9F46-4D6A6619874C.jpeg
    375E4A58-0FA4-440D-A23E-39ABD9FB98CD.jpeg   1F779CDA-3894-4528-9C02-14D817B29820.jpeg   1A70D813-1EEC-4E5F-9362-A91BFADF2413.jpeg
    Nov 2010
    177
    Re: DesignEdge cutting length measurements off
    03-07-2021
    Those photos are useless. Too blurry. however, I would be glad to help you figure out the problem, if you have not already done so. Where are you located?
    Joe
    >>>> addmenow (at) mail (dot) com <<<<
  1. Replies: 3
    Last Post: 03-16-2019, 12:47 AM
  2. Replies: 14
    Last Post: 08-23-2016, 06:20 PM
  3. Replies: 6
    Last Post: 03-19-2016, 02:15 PM
  4. 9mm SMG Project using PlasmaCAM/DesignEDGE
    By JettJJackson in forum PlasmaCam
    Last Post: 04-08-2015, 06:53 PM
  5. Cutting deeper than cutting length
    By magudaman in forum CNC Tooling
    Last Post: 10-10-2011, 04:36 AM
