586,113 active members*
3,515 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc -18 (MATSUURA 450) parameter for hold tool in spindle
    Hi!
    I need help to find parameter.
    The double arm of the machine insert tool in the spindle. I need to know the timeout to hold the tool befor turn the double arm back.
    My timeout is small now and the spindle did not clamp the tool and double arm take of the tool from spindle.
    Can anybody know where to dig?
    Re: Fanuc -18 (MATSUURA 450) parameter for hold tool in spindle
    The setting will probably be in your DATA tables. You will need the machine builders information as to what bit to change. This will not be a Fanuc parameter.
    The problem you're having is not because of the timer being too short, but something is wrong in the tool pusher. Check you air/hydraulic release cylinder for leaks or low oil level. Bleed the hydraulic lines for the tool release. Air in the system will slow the release or cause it to fail.
    The timer worked in the past. It should also work in the present, unless somebody messed around with it.
    Sorry, not DATA tables but TIMERS.
  1. fanuc 10 t tool wear offset parameter
    By karthick in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2014, 11:15 AM
  2. Fanuc 15-TT Spindle Jog Parameter
    By Rocketnsam in forum Fanuc
    Last Post: 09-19-2012, 05:30 PM
  3. Replies: 9
    Last Post: 01-14-2012, 12:00 PM
  4. Replies: 3
    Last Post: 11-03-2010, 02:11 PM
  5. Hold to hold tool holder while loosening nut
    By NXTwoThou in forum CNC Tooling
    Last Post: 02-24-2009, 10:15 PM
