586,055 active members*
4,182 visitors online*
    Mar 2005
    28
    A New Attempt.
    Although I built a LPG furnace of my own design a few years back which was quite successful and I did a few pours with it, - Circumstances at that time , however were not so good and I ended up losing it.
    I have decided to give it all another go, using materials, which I have still lying around, mostly left overs from my previous attempt . - I found a bag of flint clay, and some Mullite Mortar along with silica sand, coarse river sand and also a bag of perlite. - other stuff I have is a small amount of fireclay, left over castable refractory concrete and also some sodium silicate.
    Question is, can someone please give me some good advice on how to make proper use of all this material,and how to mix itl from the point of view of building another furnace. -
    Thanks Will.
    Apr 2004
    5737
    Re: A New Attempt.
    Use the castable refractory to line your furnace, keep the rest of that stuff for other projects. If you don't have enough refractory, get some more.
    Andrew Werby
    Website
    Mar 2005
    28
    Re: A New Attempt.
    Thanks, - Yeah, I was toying with doing that anyway (till I saw the price of the stuff!) but much easier I guess, even if it hurts a bit at the start! - That and the crucible will be the main cost, everything else I can make myself! (and have done before)
    I enjoyed doing it all then and I probably have the capability of doing this one (probably only this one), before it's too late for me to do any more! - it's got to see me out and it's got to be safe. So I guess, no 'Heath Robinson' stuff! Cheers, Will.
  1. My first attempt
    By gonzapa in forum Uncategorised WoodWorking Machines
    Last Post: 12-31-2009, 11:15 AM
  2. First Attempt help
    By sYmbot2 in forum Community Club House
    Last Post: 09-10-2008, 11:55 AM
  3. my first attempt
    By v2tiller in forum DIY CNC Router Table Machines
    Last Post: 06-28-2008, 06:44 AM
  4. first attempt
    By corrie in forum Musical Instrument Design and Construction
    Last Post: 01-06-2008, 03:22 AM
  5. My first attempt
    By Caprirs in forum Vectric
    Last Post: 08-28-2006, 08:27 AM
