586,103 active members*
3,599 visitors online*
Results 1 to 7 of 7
    Apr 2007
    trial software for newbie
    First time I've ever tried this forum thing. we'll see how it goes.
    I am looking to build a CNC mill/lathe for woodworking. I want to be able to cut XYZ axis and rotate about the x axis (A rotation I believe). I know nothing of CNC controls or have I ever worked with a CNC machine. I want some software I can play with to make sure my new contraption will work before I spend hundred on building the machine. Any suggestions for a free program or good trial software that will allow me to learn a little about CAM and CNC process? I am really wanting to turn barley twists and indexing cuts (flutes) I am an engineer and understand CAD well. but CAM and CNC not so much. any info would be greatly appreciated.
    Jul 2007
    60
    You can get a evaluation version of Solidcam from their website. It won't generate NC though, you can only play around with the operations. But that can teach you quite a bit.
    Thing is, I don't know if it will run without Solidworks. But it's free to try.
    I don't know of any wood lathe specific CAM software out there. The trial of MeshCAM will do 4 axis code from an .stl file, and the trial of Mach3 will show you how it will run. You may find that indexed flutes would be best coded by hand, and perhaps the twist as well, for the most efficient machining.
    Oct 2004
    118
    Here's what I did
    I'm still new but don't , 4 axis and software = thousands
    I started with Mach 2 ,sheet cam and mesh cam demos played with those
    Then I bought the xylotec 3 axis set, put a drawing in and watched as the motors spun , then I built the z axis repeated the above then made the y axis to hook that to then in a weekend threw together a x axis to put the whole mess on.
    I did this so I had a understanding of how this whole process works at every step.
    Oh and religiously spent hours/days/weeks/ months glued to cnc zone .
    That was the most important part, the knowledge these guys have , allowed me to complete my router and actually be able to use it.
    So in short , the answers you seek are probably here
    Oh Almost forgot , mesh cam takes stls pretty good had no luck with dxf.
    "MOI" is beta testing free for now ware , that is easy to use and outputs stl's that mechcam can use.
    Welcome to the zone
    Dave
    Apr 2007
    Thanks for the input. I will try to download some software and check it out. I plan on getting the software and playing then buying a xylotex four axis and playing some more.
    I would really like to understand how to hand code any good suggestion on how to learn. I did some computer programming in college. Q basic and fortan mostly. I've never seen CNC code... suggestions?
    Jul 2007
    60
    Well, I am a software developer by day. I've done some G coding already but it's incredibly repetitive and error-prone without an IDE. If I were to do any serious NC programs without CAM software, I would write my own program to generate G code for me from simpler or more verbose commands. Essentially creating my own post-processor which is what the CAM packages do.
    The real benefit of using another language, is you can use that language's features, objects, functions, etc. If your controller supports it, you can use macros in G code but it only a marginal remedy. If you are experienced with another language, I would suggest you write your own G code generator.
    Cheers.
    Jul 2006
    18
    I hand code a lot of my stuff, it's not difficult. There is a nice summary of Gcode commands in the TurboCNC manual (http://www.dakeng.com/), and it's free.
  1. Newbie needs some help with software.
    By Drad98 in forum Community Club House
    Last Post: 01-23-2007, 05:58 AM
  2. Newbie needs software direction
    By CNCPUP in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-01-2006, 06:31 PM
  3. 30-day trial of SYNERGY CAD/CAM Software - Free!
    By nanmol in forum News Announcements
    Last Post: 11-16-2005, 10:37 PM
  4. Newbie Testing/Trial Software Question
    By clevster in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-09-2005, 06:13 PM
  5. Newbie software confusion
    By jcolley in forum Uncategorised CAM Discussion
    Last Post: 01-24-2005, 10:48 PM
