586,035 active members*
3,797 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > how to use vfd for old cnc mill
Page 4 of 6 23456
Results 61 to 80 of 111
  1. #61
    Apr 2012
    63
    Re: how to use vfd for old cnc mill
    Is the VFD Drive U V W connected direct to the Spindle Motor check the motor wiring connections that you have it setup for 230 / 240V
    The Default was fine to start with for the Acceleration and Deceleration, if it trips out with Acceleration then it would need to be increased but with such a low RPM you are using you most likely will be able to decrease it once you get it running
    changed the settings as instructed and its working now. forward and reverse work. i changed the initial startup frequency to 60 so the motor runs at the designed speed. I left the max at 100 hz but i dont know why I would ever use that. I have a 2 speed with hand crank for speed adjustment so I will probably just run it at 60hz all the time.
    I dont have an automatic tool changer so manually setting the speed doesn't seem like an issue.
    I have not started working on bringing in the signal wires to control the VFD.
    i want to mess around with the lube system a bit more to make sure that its working properly before i get too aggressive with the spindle speed
  2. #62
    Aug 2009
    1573
    Quote Originally Posted by jaysihn View Post
    ...good idea...the waylube too. maybe write a little warnup program for xyz
  3. #63
    15362
    It would mean that you don't have to turn the hand crank to change the speed you just command the speed in your program and the VFD Drive will run it at that speed, so that is why you would use it with the 100Hz setting which is conservative for your spindle motor, at 120Hz the motor will double it's rated speed which it can do safely
    Mactec54
  4. #64
    Apr 2012
    63
    so the motor is safe to double speed but what about the spindle bearings? i think the max speed on the hand crank is 3000. if i wanted to leave it in that position and over-drive the motor, do you think the spindle bearings can handle 5-6k RPMs ok? that would open up the ability to do some smaller diameter cutters
  5. #65
    Aug 2009
    1573
    ... higher speeds more heat. Depending on your machine condition, Vbelt drive, gearbox lube/mist system, temperature, etc...running at very high speeds for short periods probably ok.
    ...safely is a matter of opinion.
  6. #66
    24221
    I have generally used the typical 4 pole motor, as yours appears to be, at least twice the plate frequency when incorporating a VFD,
    I speculate that the motor manuf. probably produces 2 pole motors also, so I would imagine that he would use the same balancing and bearing specifications for the whole line of motors. 2 & 4 pole alike.
    Al.
    Albert E.
  7. #67
    Dec 2013
    5717
    That particular motor that you have is rated at 6000 RPM max, I have the identical motor on my mill. I would not run it over 4500 RPM. I'm guessing the spindle would take 6K RPM with no problem. If you need higher than that, then time to add an auxiliary spindle.
    Jim Dawson
    Sandy, Oregon, USA
  8. #68
    15362
    Not with this standard 4 Pole motor you are not going to run it at 6,000 RPM, it's rated RPM is 1725 so 3450 is around the max for this motor, did you check the motor he posted
    Mactec54
  9. #69
    Dec 2013
    5717
    Yes I looked at the motor he posted. I have exactly the same motor on my mill. I actually looked up the specs on the motor when I was doing my direct drive conversion and the Baldor data sheet says the absolute max RPM on that motor is 6000.
    I don't just come up with this stuff off the top of my head.
    Jim Dawson
    Sandy, Oregon, USA
  10. #70
    Apr 2012
    63
    thanks Jim. I'll keep the max freq at 100 Hz until i've got some time on the machine and get more comfortable with its limits.
    did yours have the weird brake on the motor? I took that off tonight - none of its wires were hooked up.
  11. #71
    Dec 2013
    5717
    When I was still using the mechanical variable speed on mine, I normally ran between 30 and 90 Hz. That covered all of the speed range I needed. It was just easier to reach up and turn the knob on the VFD key pad than to crank the mechanical variable speed unless I needed a large adjustment. I had the VFD mounted where the motor switch would normally be on a manual mill. After running manual mills for about 45 years, it felt normal to reach up into that area to control the motor.
    No, mine did not have that breaking system, I think that was added by the machine builder. The Baldor braking system is different on motors equipped with that.
    Jim Dawson
    Sandy, Oregon, USA
  12. #72
    Aug 2009
    1573
    i am just trying to educate myself.
    control not responding to PIC
    ...me too.
    and something that is still stuck in my mind following your thread is the photo of the Dynapath unit you posted early on. Almost all of the cards seem to be in the wrong slots. But, yet you say the machine powered up ok...... if, you are having any trouble with odd behavior. Be on the outlook for problems...like axis missing information on screen, positioning errors, soft keys, keypad functions,mode selecting, programming or anything odd. Or maybe the photo is not the card configuration of your machine currently is. Looks like the Battery is missing too
    This message will self destructed in 15 secs, after answered...
    DJ
    Attachment 445168
  13. #73
    15362
    Post the spec's sheet then he has a 4 Pole motor, they have not made this motor in years so don't know where you got the spec's from I have all there motor catalogs for the last 10 years and it is not a listed motor
    Mactec54
  14. #74
    Apr 2012
    63
    pretty sure its closer to 30 years old.
  15. #75
    Apr 2012
    63
    Quote Originally Posted by machinehop5 View Post
    ...me too.
    DJ
    Attachment 445168
    Attachment 445172Attachment 445174Attachment 445176
    battery is there. I had this machine sitting without power since October 2019 and when I got it powered back up it didn't have any battery warnings.
    maybe this is an even older delta10 unit that had the cards in a different order?
  16. #76
    Dec 2013
    5717
    That motor is close to 30 years old. The data sheet that I found no longer seems to be available on the internet. It was several years ago that I found it and apparently I did not download it. When ABB bought Baldor, it seems they took down all of the old data sheets.
    Jim Dawson
    Sandy, Oregon, USA
  17. #77
    Aug 2009
    1573
    ...I dont think the Dynapath 10 were smart enough to monitor battery condition.. easy to check with a voltmeter and power off. should be more than 3VDC if good. Battery only holds programs and offset memory during power off. There is a date on the battery maybe if, you look close. No biggee you have bigger fish to fry with this project. Keep going
  18. #78
    Apr 2012
    63
    Attachment 445184
    my serial number is pretty close to the 60,000 when they started delta10 with 6MHz hardware. makes me think its probably from 1986-1988.
  19. #79
    Aug 2009
    1573
    Attachment 445184
    ...looking back those were some good times...Cutting edge. of G code robots. Nice that the machine you have is in great shape...looks like.
    https://en.wikipedia.org/wiki/Intel_80186
    https://www.ebay.com/itm/Dynapath-42...gAAOSw9~Ne3utl
  20. #80
    15362
    The spindle bearings can handle over 10,000 RPM in general the spindle is not the problem it will be the variable drive in the head that will fail first 4600 is usually about the max for a variable drive without a lot of mods that is about the max for a head like that , the only way to get high speed it to remove the variable drive and direct drive
    Mactec54
Page 4 of 6 23456
  1. Replies: 2
    Last Post: 05-16-2016, 01:08 AM
  2. Replies: 0
    Last Post: 04-01-2016, 07:54 PM
  3. Replies: 0
    Last Post: 03-27-2016, 04:52 PM
  4. Replies: 0
    Last Post: 02-13-2016, 04:47 PM
  5. How to drill and face mill using table type horizontal boring mill
    By SatishNaik in forum News Announcements
    Last Post: 10-09-2013, 01:10 PM
