Code:
4.7.2 Speed parameter
1,X-axis's G00 speed(mm/min) 10000
2.Y-axis's G00 speed(mm/min) 10000
3.Z-axis's G00 speed(mm/min) 4000
5.Manual maximum feed speed(mm/min) 12500
6.Auto Maximum feed speed(mm/min) 12500
7,G01/G02/G03 default speed(mm/min) 4000
8,Null run speed(mm/min) 10000
9,Feeding axis`s manual speed(mm/min) 10000
10,Spindle`s manual speed(rpm) 12000
11,Beginning feed speed(mm/min) 50
12,The maximum mutation of feeding axis speed(mm/min) 50
13,Limit G1G2G3 axis speed [1meanYes,0meanNo] 0
14,XG1G2G3 max speed (mm/min) 12500
15,YG1G2G3 max speed(mm/min) 12500
16.ZG1G2G3 max speed(mm/min) 12500
18,X acceleration [1?99999] 10000
19,Y acceleration [1?99999] 10000
20.Z acceleration [1?99999] 5000
22,Auto run acceleration [1-500] 1
23,Handwheel acceleration [500--30000] 1200
24,Run program Handwheel acceleration [>500] 60000
25,Run program Handwheel G00 speed(mm/min) [>10] 1500
>There’s another parameter here that’s not listed in the manual: 25-1 Run Program Handwheel g00 start speed 100
26,Handwheel X limit speed(mm/min) 4000
27,Handwheel Y limit speed(mm/min) 4000
28.Handwheel Z limit speed(mm/min) 4000
30,Acceleration type [0meanline,8meancurve] 0
31,Curve initial acceleration [>=10] 100
32,Curve acceleration with second-order [>=10] 100
33,Curve max acceleration [>=500] 1000
34,X go home positive speed(mm/min) 3000
35,X go home negative speed(mm/min) 100
36,Y go home positive speed(mm/min) 3000
37,Y go home negative speed(mm/min) 100
38.Z go home positive speed(mm/min) 3000
39.Z go home negative speed(mm/min) 100
42,Spindle max speed in the first gear(rpm) 18000
43,Spindle max speed in the second gear(rpm) 2500
44.Spindle max speed in the third gear(rpm) 2500
45,Spindle max speed in the fourth gear(rpm) 2500
46,Second Spindle max speed(rpm) 2500
47,G02/G03 reverse compensation mode (0meanA;8meanB) 8
48,mode B reverse compensation speed (mm/min) 3000
48-1,mode B reverse compensation Beginning feed speed(mm/min)[>10] 500
48-2,mode B reverse compensation acceleration(mm/min)/s)[>10] 60000
49,Speed mode[1meansyes,0meansno] 1
50,Handwheel stop speed(mm/min)[>100] 100
There are four extra paramenters not listed in the manual here:
51 Follow the tapping knife when the spindle speed 1
52 When tapping spindle backlash compensation 1
53 Follow the tapping cutter withdrawal after reversal 1
54 Tapping back speed 1
58,Forcedly limit drop speed critical(mm/min) 1
> The following are not listed in the SZGH manual, but are in the NewKye manual
60, smooth running function 28
61, smooth running time 50
62, handwheel smooth running time 50
63, G01/G02/G03 smooth running time 50
101, X-beginning feed speed 500
102, Y-beginning feed speed 500
103, Z-beginning feed speed 500
111, X-jump speed at continuous track 500
112, Y Jump speed at continuous track 500
113, Z jump speed at continuous track 500
200, G00 continuate run is valid 1
> The following are not listed in either manual
230 SP G00 speed 1000
231 SP G01 mode 4
232 SP Direction 0
233 SP back to zero control mode 0
234 SP stop angle 0
235 SP back to zero speed 800
Oddly enough, the SZGH manual says I should use linear acceleration for stepper motors (which this machine has), while the NewKye manual in front of me says " 30: The parameter is about the driver configuration, in generally, set as curve when match the stop, set as straight line when match servo"
