586,047 active members*
3,931 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, is it possible to use g22 for c axis ?
Results 1 to 11 of 11
    Jun 2015
    4154
    hello, please, is it possible to use g22 for c axis ?
    i wish to rechuck a part with a side hole, and orientate the hole among x axis / kindly
    Apr 2009
    1262
    Re: pls, is it possible to use g22 for c axis ?
    I don’t believe it is possible because it is a spindle drive and not an axis drive. Have you tried it?
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hy mr wizard no, it didn't work
    Code:
        G29 PC=30 ( 2277-01 ALARM-B DATA WORD torque limit A side 1 )
        G22 PC=25 C+10 F+60(100*5) G94 D+12.5 ( L0 still going )
        G28
    upper torque limit is at 60%
    but look what i found inside error's description ( is like there is possible to use PC and PM ) :
    Code:
    7 ->When it was not C axis connection, PC instruction was done by G22/G23/G29.
    8 ->When it was not M-axis specification, PM instruction was done by G22/G23/G29.
    9 ->PW and WT instructions were designated at the same time by G22.
    i may be missing something, because it did not showed " no-spec alarm " / kindly
    ps : please, what means WT from point 9 ?
    Apr 2009
    1262
    I think M110 is not active?
    Jun 2015
    4154
    hello again no, m110 is there, i just did not shared the entire code
    Code:
        G00 X500 Z250
        T909 M110 M960 M808
        G00 C0 X150
        G01 C1 F=60 G94
        G22 PC=25 C=10 F=60(100*5) G94 D=12.5 ( L0 still going )
        G28
        M807
    voila
    Jun 2015
    4154
    if you wish, please check attached seems that such an option was released recently
    Apr 2009
    1262
    Now that’s a new one! Never seen it before.
    I’m guessing there is a new torque limit parameter for c axis then?
    Best regards,
    Jun 2015
    4154
    hy, i think that this capability is there from some time, as PC appears inside manuals, in G22 context; it may be spec, but it hadn't been presented so far
    from time to time, i scroll the okuma website, and recently i saw it
    i think that torque limiter parameter is the same as the existing one, as it is targeting only the upper limit, beyond which is not allowed to pass when using G29
    a few months ago, when i needed this, i simply used spindle's phase ( CD on screen ), and a live tool that was aligned among X axis, but offseted in Y; normally, Y offset should have been 0, but sometimes is possible to go like that now, looking back at it, i think i could have ignored also the X alingment
    is possible to have same origin for C axis and M19, so to switch between them without losing phase / kindly
    Jun 2015
    4154
    solved ... if you wish, check attaced
    hy mr wizard, the capability is there from more than 10years ago, only that manuals are not updated; thus even new revisions are incomplete on some topics
    this function popped in the manuals around 2020 ... and there are still many hidden things
    hello past self of myself that's because alarms related to missing specs are not always the same
    this works only for static/positioning, because as rpm increases, it will offset the m19 origin ... still, can be solved
    you where thinking ? haha ... i found some of my stuff from 2018, and i was so stupid .. same for 2021, and i may still be, and miss a big thing ?! i just don't see it now, but, omg !
    Dec 2008
    3109
    Quote Originally Posted by deadlykitten View Post
    Kitty.... go see a doctor, please
    You seem to have lost something.
    Your mind.
    Jun 2015
    4154
    it is a good loss ... benefic
  1. Replies: 1
    Last Post: 01-28-2024, 06:26 PM
  2. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  3. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  4. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  5. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
