586,036 active members*
3,695 visitors online*
Results 1 to 10 of 10
    Jun 2020
    4
    Unhappy VFD control, Acorn+ E550
    I'm fairly new here. I recently added a new spindle onto my PM25. Im fairly new to building, or doing anything with this small of a mill, let alone electronics.
    I just run them for a living haha.
    Spindle mount is made, spindle works fine and vfd works fine as far as controlling the spindle from the VFD.
    I have a analog signal 0-10v from acorn going to my vfd, and fwd from output/relay.
    Analog 0-10v does not seem to work by its self. Fwd is off common and x1 does start the vfd, then prompts spindle fault on my controller. : (
    Vfd fan turns on and then back off. No error on vfd.
    Idk what's going on and I'm still.learning this controller/vfd.
    I may have a setting on the VFD that is incorrect.
    Spindle works fine when ran directly from vfd, so iunno.
    Any ideas ??
    https://purelogic.ru/data/docs/elekt..._manual_ru.pdf
    Aug 2009
    1573
    Re: VFD control, Acorn+ E550
    ...there is a VFD parameter for keypad or remote control or something like that. depends your Brand/Model VFD..Can you post the Manual/ Parameter list?
    DJ
    Aug 2009
    1573
    ...looks like F0.00 is set to 3 default.... should be changed to 1 for External analog freg control...see page 20. See if that works. Check F0.02 also for what setting it is..
    Feb 2008
    280
    What Acorn input did you define for "SpindleOk"?
    What VFD terminal did you connect to that input?
    What value do you have in F1.13 or F1.14, as applicable?
    Jun 2020
    4
    Quote Originally Posted by machinehop5 View Post
    That is set correctly.
    F0.00 is 1
    .02 is 1001 iirc
    - - - Updated - - -
    Quote Originally Posted by cncsnw View Post
    I have the spindle ok feature disabled on inputs.
    Is it required?
    Aug 2009
    1573
    ...on page 14... do you have the Jumper set correctly for 0-10v ?
    Feb 2008
    280
    Interesting. I didn't think it was possible for the CNC12 control software to report a spindle fault, without a "SpindleOk" input defined.
    If you continue to have difficulty, post on the Centroid community support forum.
    Be sure to include a Report from your control so that those who are inclined to help you can look at your configuration, PLC program, and message logs. Also include a picture or diagram showing all of your control wire connections between the Acorn and the VFD.
    Jun 2020
    4
    Jumper is set correct
    Jun 2020
    4
    Its still in the inputs just marked red.
    I'll remove it completely to just see what it does.
    Dec 2009
    521
    Quote Originally Posted by HellZone View Post
    For proper support, please post to the Centroid Acorn User's forum.
    https://centroidcncforum.com/viewforum.php?f=60
    Please follow this post for the protocol. We need more information than you are providing
    https://centroidcncforum.com/viewtopic.php?f=60&t=1043
  1. Lathe turret control with an acorn
    By upnorth in forum Centroid CNC Control Products
    Last Post: 05-13-2019, 08:46 PM
  2. Centroid Acorn add DIY & Complete Control Replacements for ShopBot
    By islaww in forum Centroid CNC Control Products
    Last Post: 03-12-2019, 06:16 AM
  3. Lathe turret control with an acorn
    Last Post: 02-15-2019, 02:16 PM
  4. Replies: 4
    Last Post: 12-16-2018, 02:11 PM
  5. Can Acorn control rotary on router with dual y motors?
    By dixdance in forum Centroid CNC Control Products
    Last Post: 03-21-2018, 03:46 PM
