586,061 active members*
4,414 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Need Okuma software
Results 1 to 8 of 8
    Sep 2008
    138
    Need Okuma software
    Dear all
    I have Okuma MDB with OSP-7000M, the battery was flat, so I need the software for reinstall to my machine, I'm willing to buy it
    Apr 2009
    1262
    Re: Need Okuma software
    All machines come with software in the electrical cabinet. If yours is gone, then you will need to get a new set from Okuma through your local distributor. Software is machine specific by serial number although if you can find the same machine with the same hardware spec, their software will work in a pinch.
    Best regards,
    Experience is what you get just after you needed it.
    Sep 2008
    138
    Thanks you very much . But I'm still want to find the software not from Okuma local distributor
    Apr 2009
    1262
    So it’s software is gone from the electrical cabinet? There are only a handful of those machines around and most are built with very specific options. That control is 4 generations old so your odds aren’t too good.
    Just so you know...
    Jun 2015
    4154
    hy, with a bit of luck, you may succed ... but i am reserved about chances
    like mr wizard said, software is unique for each machine; even on modern identical machines, you can not install same software pack
    i am not sure if the software also includes machine parameters, as i once heared that someone failed to install the osp, so it was needed that a japanese would came and re-initialize his parameters
    those software are pretty well packed ( okuma protection ), making it hard for a mere mortal to make a software compatibile across different machines
    in the end, you may still need to contact an okuma agent / kindly
    Jun 2020
    5
    HELLOW GUYS ,
    SORRY FOR MY question ,HOW CAN I MAKE NEW POST IN THIS FORUM
    Apr 2009
    1262
    At the top hit the POST NEW THREAD button.
    Apr 2006
    111
    Quote Originally Posted by greenery_fr View Post
    Dear all
    Hi
    Has your CNC machine been repaired yet? I have the solution without the original software disk that came with the machine
  1. Okuma lb 15 osp 5000L-G Software
    By xal3r in forum Okuma
    Last Post: 11-08-2020, 03:12 PM
  2. Replies: 0
    Last Post: 01-07-2019, 04:49 AM
  3. OKUMA MC-500H Software!!
    By bbarber80 in forum Okuma
    Last Post: 06-05-2012, 01:00 PM
  4. Okuma CNC OSP 500L-G --- Cam Software
    By rajappa in forum Okuma
    Last Post: 06-18-2008, 01:21 PM
  5. New Software for Okuma
    By psevin in forum News Announcements
    Last Post: 08-15-2006, 04:25 PM
