586,119 active members*
3,325 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Best Cheap Smartwatche - 2020 model
Results 1 to 1 of 1
    Jun 2020
    The smartwatch I have had for a few years, and yet the best in the range, is still not affordable for most people. However, this does not mean that there are inexpensive smart watches with great features, which might be right for you.
    You probably thought about going for a cheap smart watch, because you never had one, and you want to know if you need to simplify your life.
    In the article I propose, you will find a good list with all the models of cheap smart watches with excellent performance, and it is worth noting. 4 4
    Best cheap smart watch
    The world of wearable or wearable devices, as used in recent times, is very vast, and you know that when you pretend to be cheap, the result is often not what you expected. ... Actually, money is often wasted.
    YAMAY IP68 smart watch
    The best cheap smart watch: YAMAY Smart Watch IP68 It has a super lightweight aluminum case, the screws are stainless steel and rubber strap. The charging cable is magnetic, so it won't have a port.
    In addition to the classic fitness tracker features, this smartwatch also adds the ability to dive into water or wear it during a shower as it is IP68 certified, meaning waterproof.
    It has a 1.54-inch screen and is compatible with Android and iOS smartphones and all this is possible by downloading the "Fundo" application from the respective stores.
    Once set up, the smart watch will continuously monitor your sleep, health and many other wellness factors, also interacting with the applications installed on your smartphone.
