I apologize for the cross-post, this appears to be more related to the FANUC channel.
After buying a machine with a dead battery, I have reinstated almost all parameters. The last bit I need to do is to modify the PMC data. Unfortunately I cannot write to these data; I get a "write protect" error every time.
What is the standard method for writing to PMC data? I have tried in MDI, EDIT, e-stop on and off, "Parameter Write" enabled and disabled (under Offset Setting x2). I've googled the heck out of this but cannot find an answer.
Thank you for any help!
