586,102 active members*
2,555 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > LB15 "2561 RS232C ready interrupt time out error"
Results 1 to 8 of 8
    Jul 2007
    143
    On my LB15 (1990) all of a sudden when I try to send data to the lathe I get this error "2561 RS232C ready interrupt time out error".
    From lathe to PC no issues. Never see this before.
    Same cable same programs. Any ideas?
    Aug 2011
    419
    Re: LB15 "2561 RS232C ready interrupt time out error"
    Maybe there is a wrong parameter set
    "Imagination is more important than knowledge."
    Jul 2007
    143
    Quote Originally Posted by kurmay View Post
    Yes I suspect you maybe correct, I just tried a second PC and it does the same ie CNC to PC ok but PC to CNC after data transmits I get the time out error.
    For the LB15 lathe with a 5000 L-G control do you know the parameters?
    Apr 2009
    1262
    Your error message means that it is not receiving the “go” signal in the allotted time. Check Parameters like Kurmay says to see if XON/XOFF or software handshaking is selected. Not very likely the machine settings changed but much more possible on the PC. Check there first then be sure to READ on the machine before sending from the PC.
    Best regards,
    Experience is what you get just after you needed it.
    Aug 2011
    419
    Aug 2009
    1573
    ...good time to backup the Parameters what ever they are set at currently...if you can still send to PC. other possible things to check I've seen failed/weak memory batterys cause problems. Bad grounding, RF noise near the cable.
    Feb 2024
    I am facing the same issue now. But when I checked the parameters it looks like it has gone back to the original values. I changed parameters back to what is recommended in the online forums to no result. Has there been a fix for this issue?
    Mar 2009
    1982
    Did You try to find out the reason of the fault?
  1. Replies: 1
    Last Post: 03-27-2018, 11:44 AM
  2. Error 152 "Drive not Ready"
    By moldcore in forum Milltronics
    Last Post: 09-10-2017, 04:37 PM
  3. OSP 5020L on LC-30 "2561 Error" Help
    By TriumphMachine in forum Okuma
    Last Post: 03-23-2012, 09:31 PM
  4. 2561 Time Out Error
    By mbm in forum Okuma
    Last Post: 06-25-2011, 02:41 PM
