586,108 active members*
3,069 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > THK combined LM rail with gear rack
    Jul 2020
    Hi all.
    I'm in the process of designing a CNC router. The Table will be 4m x 1.8m approx..
    Has anyone used the THK LM GSR-R combined linear rail with integral gear rack?
    If so any feedback?
    Cheers GV
    May 2005
    3920
    Re: THK combined LM rail with gear rack
    Nope haven’t done that. However such a rail system should reduce alignment errors.
    I'm going to assume that it's far more expensive than most DIYers would be willing to spend. But It's probably a very good system.
    Jul 2020
    Ok so got in touch with the distributor today.
    Wont work.
    Too expensive about AU$6000 for 10Lm
    Also they have to be fixed flat, I want to mount them on the side of the machine so another linear rail would be needed to stop I flexing off.
