586,075 active members*
4,320 visitors online*
Thread: OKUMA LT10-M
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Re: OKUMA LT10-M
    Hallo
    Here are the pictures.All operation in graphic do just tool that is curent selected in turret .
  2. #22
    Apr 2009
    1262
    Re: OKUMA LT10-M
    If you remove the M66 from the program, does it react differently? Also test with 6 digit T commands. I've seen this happen on machines with the ATC, but not on yours. Can you take a pic of the tool graphic setup screen for one and two please?
    Experience is what you get just after you needed it.
  3. #23
    Re: OKUMA LT10-M
    Hi
    Mr. OkumaWiz
    I remove M66 from program and also try with 6 digit on T (T010101,030303) but dont work in graphic. Heres are pictures of the tool graphic setup screen.
    Best regards
    Attached Thumbnails Attached Thumbnails IMG_1516.JPG   IMG_1517.JPG   IMG_1518.JPG
  4. #24
    Apr 2009
    1262
    Re: OKUMA LT10-M
    OK, your pics look good and I'm assuming there are no duplicates. Did you run the program in auto with machine lock off to see if it still worked without the M66? I want to be sure that it is going to either the +X or +Z limits before indexing. M66 would ignore that requirement and is generally somewhat dangerous and should be avoided. You can typically reach the limit before the turret can unclamp anyway, so little time is saved and it's MUCH more dangerous. Use M203 as you rapid to the limit in order to unclamp on the fly as you go to the limit. Safer and Faster.
    Best regards,
Page 2 of 2 12
  1. Spindle synchronization problem LT10-M
    By hamaf in forum Okuma
    Last Post: 10-04-2016, 02:33 PM
  2. Okuma LT10 OSP 7000L
    By cmp79 in forum Okuma
    Last Post: 02-15-2016, 09:59 AM
  3. Okuma LT10-m
    By age_cph in forum EdgeCam
    Last Post: 04-28-2011, 10:26 AM
  4. OKUMA LT10
    By clp_00 in forum CNC Machining Centers
    Last Post: 07-10-2008, 09:22 PM
  5. Replies: 6
    Last Post: 12-03-2007, 01:32 PM
