586,060 active members*
4,027 visitors online*
Results 1 to 8 of 8
    Aug 2013
    13 chrome turning
    Another Question on the machining side of 13%Cr material:
    Do you have a maximum machine speed to machine this type of material perhaps, based on your experience? (We currently machine at 134m/min with one type of insert and 112m/min with another type on the same material)
    Are there anything else that is crucial to machining this type of material with acceptable surface finish, for example max tool stick out or something that also needs to be considered?
    Jun 2015
    4154
    Re: 13 chrome turning
    hy, a while ago i prepared a long series setup, for a few months, in 41Cr4, 42-47hrc, cutting at 170M/min, using a mapped feed between 0.1 and 0.5mm/o, diametral doc 2.25
    i could have gone above 170M/min, but i did not wanna go beyond 2000rpms on the 250mm chuck ... i consider it to put to much stress on the spindle above that value, and also there was a long bar inside a spindle liner custom built
    changing inserts once/shift, etc
    using kyocera and walter, W and later D geometry, rad0.8 - 1.2 ... if you wish, i will look for more informations about those inserts
    toolholders had been modified, coolant holes had been increased, and also there were 2 coolant nozzle / cutting edge, one from above and another from below
    normally, few people look into such things, and in most cases having coolant on the top of the insert seems nice, but in reality it hits the chip, not the cutting edge ... this does not matter in most applications, because toollife seems to be ok, but when turning hard materials, such details can make a huge difference
    oh, yes, i almost forgot : coolant concentration was >10%, or, if you wish, coolant was much more concentrated then on a regular day, and it was making bubbles
    onestly, there is not so much difference between those 2 values
    max tool stick out
    during long setups i use to push specs really hard, and i noticed that a tool with less overhang will be more stable ... otherwise, the lathe will start to vibrate, just like when you move a heavy fridge or something, is a very unpleasant noise
    to achieve repetability and avoid re-checking the colisions, i use to write down offsets value, and also check them inside the program
    i would say that you have to design the toolpath&cutting-specs in such a way, that minimizes chips tangling on the part / material / or tool ... i used to cut in reverse some toolpaths, modify them a bit here/there, etc
    you can't push a setup with chips tangling arround / kindly
    Still in Antarctica, eh??
    Jun 2015
    4154
    hy please, what do you mean by that ?
    Aug 2009
    1573
    Quote Originally Posted by deadlykitten View Post
    cool cat with sense of humor?
    Aug 2009
    1573
    Quote Originally Posted by KnuckleBuster View Post
    1st part of the humor
    Quote Originally Posted by machinehop5 View Post
    He was banned from PM.............. DAMHIKT.
    Jun 2015
    4154
    yup, it was a few years ago my god, it was such a rigid experience ...
  1. Turning Biodur (chrome cobalt)
    By beege in forum MetalWork Discussion
    Last Post: 01-16-2012, 10:07 AM
  2. Cobalt Chrome
    By eric.lefavour in forum MetalWork Discussion
    Last Post: 08-13-2010, 11:52 AM
  3. cobalt chrome
    By hebedog in forum MetalWork Discussion
    Last Post: 06-15-2010, 05:45 PM
  4. turning chrome
    By seawolf217 in forum MetalWork Discussion
    Last Post: 06-11-2009, 08:49 PM
  5. Replies: 7
    Last Post: 05-02-2009, 12:07 AM
