586,102 active members*
2,394 visitors online*
    Jul 2007
    236
    CENTROID/AJAX Personal Demo Invite
    Hello. I'd like to invite anyone interested to a informal personal CENTROID CNC control demonstration. Bring your prints and we'd be glad to show you how easy and powerful the CENTROID CNC control is. We are located in Statesville, NC and there are other participating dealers who offer in house demo's nationwide. PA, AZ, AL, WA to name a few other locations. We are real "down to earth, get the job done right retroffiters" and we'd like to invite you to come and see for yourself how a CENTROID CNC control can make your projects better and easier. -Keith
    Apr 2007
    175
    Dang Keith, I wish I was closer..
    Nov 2005
    244
    Retrofit a Southbend Magnaturn 12x18
    Hi
    I have a Southbend Magnaturn I would like to retrofit. The machine uses hydraulic cylinders to drive the X and Z axis and uses scales for feedback.
    No rotary encoders or ball screws on this machine.
    Can this machined be retrofitted with a Cncajax control? If so what would a very rough guess be?
    Thank You
    Jul 2007
    236
    Examples of Typical Lathe CNC Retrofit Packages:
    Hello.
    Examples of Typical Lathe Retrofit Packages:
    1. Lathe Retrofit using Existing Servo Motors
    Lathe Kit $ 2459
    Control Pendant $ 639
    (2) Servo Encoder $ 250
    (1) Spindle Encoder $ 125
    (3) Encoder Cable Prewire $ 177
    Cap & Bridge Combo $ 69
    Total $3719 + S&H
    the bad news is the Magnaturn is somewhat of an oddity and would require alot of mechanical work to covert it to typical ballscrew style CNC machine. If you had alot of time and could get the screws for cheap it might be worth it.. otherwise..sell it and find another lathe that would be a better candidate for a retrofit upgrade. good luck with your projects..
    Nov 2005
    244
    Hi Keith
    I thought not having a ballscrew for a rotary encoder would be a problem.
    I have a link for a piston actuated ball screw. http://www.lsitvc.com/smartstroke.htm
    Would that work?
    Thank You
  1. Ajax/Centroid VS Prototrak
    By dk1machine in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2007, 07:01 AM
  2. Centroid/Ajax MPG plug
    By George C in forum Centroid CNC Control Products
    Last Post: 03-21-2007, 10:49 PM
  3. Ajax DOS Demo
    By ninthmp in forum Centroid CNC Control Products
    Last Post: 03-09-2007, 12:27 AM
  4. USB mouse with Ajax/Centroid controller?
    By jnutter in forum Centroid CNC Control Products
    Last Post: 02-06-2007, 02:15 AM
  5. Ajax or Centroid users
    By boringmill in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2007, 05:26 PM
