586,032 active members*
2,941 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > Citizen L32 programming question on using G75
Results 1 to 11 of 11
    Mar 2013
    18
    I have a Citizen L32 with a mitsubishi Meldas series 500 control. I wanted to use the G75 cycle for chip breaking in the Z axis . I keep getting a program error and I am not sure on what format to enter in my P Q R numbers is it in decimal form or 4 digits. If any one has a program example that woulkd be appreciated . What I would like to do is start at a .400 dia. and cut a straight line in th z axis .700 taking maybe .030 at a pass or whaytever I need to do to control the chips.
    Jun 2015
    4154
    Re: Citizen L32 programming question on using G75
    hello pls find attached infos about g75
    is this what you are looking for ? to cut the part, or a groove ? or you wish for the LFV ?
    if it is about:
    ... cutting/grooving, i never use g75, but simple g-code, for more control; if you wish, i will share an example
    ... LFV, then i may select infos from the manuals, and share it to you; i just searched, there is something, but it seems to be much more, in comparison to g75
    i saw this later, it seems you are looking for LFV ... infos are spread all over the manuals, i will search later today
    until then, just try this :
    ... increase your feed
    ... decrease your rpms
    chips are broken by increasing the feed; also, if you work at an rpm that breaks your chips, increasing the rpm may no longer break them, but make them tangle arround ... thus a greater rpm may break your chips at a higher feed rate
    i would start with a minimal M/min, and increase the feed
    however, some soft materials simply don't break easy into smaller chips; i will be back with infos on LFV / kindly
    Aug 2009
    1573
    ...using a "-" sign can cause a problem sometimes with P's and Q's or K's in canned cycles...depends on CNC.
    Mar 2013
    18
    Quote Originally Posted by deadlykitten View Post
    if it is about:
    My machine does not have the LFV but with the G75 i am looking to do kind of the same thing. I do it all the time on our Fanuc controlled Lathes. I am just looking to straight turning, I have tried everything with feeds and speeds but the material just does not break up consistently to run unattended.
    Aug 2009
    1573
    hire a pro..
    Feb 2011
    353
    If you can use macro's try this it works well on a mitsubishi m70
    G0X.400Z-.05
    G1Z0.F.0025
    #100=0(start point)
    #101=.030(peck dist.)
    #102=.700(depth)
    #103=.003(chip break)
    WHILE[#100LT#102]DO1
    IF[#100LT#102]GOTO100
    #100=#103(IF #100 GE #103 MAKE #100 THE SAME AS #103)(THIS AVOIDS OVER RUNNING THE FINAL DIM.)
    N100
    G1Z[#100+#101]F.0025
    G1W-#103(BREAK CHIP could be a dwell also to break the chip)
    #100=#100+#101
    END1
    G1X.500
    G0Z-.1
    Jun 2015
    4154
    hy jim, please, what are you doing on the fanuc, that you wish to do also on the mitshubishi/citizen ?
    is it similar to the code shared by rcs ?
    if possible, use an endmill to cut a longitudinal groove : this should break the chips when turning; obviously, this will require to lower your turning specs, and use an insert that can handle that bump, but may deliver a ' clean ' part
    another trick may be to rough towards reverse_Z, thus the oposite way ( may require an insert with bigger nose radius, so not to break during plunging ); this won't break your chips, but may throw them into the chipconveyor;
    * in both cases, may be required to adjust your operation in respect to guide bushing length / kindly
    Mar 2013
    18
    Quote Originally Posted by rcs60 View Post
    G0X.400Z-.05
    G1Z0.F.0025
    #100=0(start point)
    #102=.700(depth)
    N100
    #100=#100+#101
    END1
    G1X.500
    G0Z-.1
    Thanks it worked out well
    Feb 2011
    353
    your welcome
    Jun 2015
    4154
    hello again, recently i was talking with someone about this, and other solutions involves:
    ... cutting a "thread" with a relative big doc and lead ( at least > feed of turning operation )
    ... lfv tuned so to avoid ( or minimize ) air cut in order to extend tool life, but still break the chip / kindly
    Mar 2017
    Y axis turning tool will throw the chips down towards conveyor. All you need is a code. G140X=Y1 Y=X1 Z=Z1. G141 at the end of program to cancel. Program as regular X turning. Just put Y0. In clearance at start. T300
    G0 X.5 Z-.05 Y0. T3
  1. Programming help with Citizen A32VII
    By sthuston in forum CNC Swiss Screw Machines
    Last Post: 10-19-2018, 07:27 PM
  2. programming help citizen L20E
    By miki2432 in forum CNC Swiss Screw Machines
    Last Post: 10-05-2014, 01:48 AM
  3. Question regarding programming Citizen with Partmaker
    By colby2000 in forum CNC Swiss Screw Machines
    Last Post: 02-02-2013, 05:04 PM
  4. Citizen K16 programming
    By bvaught in forum CNC Swiss Screw Machines
    Last Post: 07-03-2008, 12:51 PM
