586,108 active members*
3,194 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc O-T on Emco 320 bar feeder removed need to disable bar feeder in the logic
    Oct 2011
    38
    I have a Emco 320 / Fanuc O-TC that is configured with a LNS Hydrobar bar feeder. I have the lathe powered up but the Lathe is expecting a bar feeder to be connected and its not available right now.
    I'm not sure how to "disable" the bar feeder, is it setup in the parameters and if so which one, or do I need to jumper out the Bar feeder or something like that.
    I can't continue troubleshooting the actual alarm that appears when the bar feeder ic connected.
    Thanks in advance
    Craig
    Dec 2009
    953
    Re: Fanuc O-T on Emco 320 bar feeder removed need to disable bar feeder in the logic
    ussually you need to jumper the emergency contact from barfeeder.
    if it is any other signal that enables the barfeeder that must be in diagnose
    if you have the diagnose printed out and have comment on it will be easy to see what bit is enable it.
  1. Help with lns bar feeder
    By Stumped100 in forum Turning
    Last Post: 11-14-2018, 12:00 AM
  2. Emco 320 Siemens 810T bar feeder 1x button
    By nicinandrej in forum EMCO Lathe
    Last Post: 03-13-2018, 08:02 PM
  3. Bar feeder oil choices to help with vibration inside the feeder channels
    By lasernerd in forum CNC Swiss Screw Machines
    Last Post: 05-19-2017, 10:59 PM
  4. What to look for with bar feeder
    By Desertrunner in forum Fanuc
    Last Post: 06-15-2012, 07:16 AM
  5. Replies: 0
    Last Post: 09-27-2010, 04:00 PM
