586,655 active members*
2,846 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 110v CNC Spindle 80mm ER20 Suggestions
Results 1 to 6 of 6
    Dec 2019
    I am in the market to purchase a 110v ER20 Spindle. I would prefer to go air cooled. Does anyone have any suggestions on a specific setup. Been looking at this kit from Amazon.
    https://www.amazon.com/dp/B06ZZSPT5R...v_ov_lig_dp_it
    15362
    Re: 110v CNC Spindle 80mm ER20 Suggestions
    Quote Originally Posted by Sandow12 View Post
    2.2Kw on 110v is junk you end up with around a 800w spindle if you have a 120v service that can run it
    Mactec54
    Dec 2019
    So what would you recommend if I don't have the option for 220v. I have not seen a ER 110v at 1.5kw. A 2.2kw at 110v and 20amp, would that still be junk?
    15362
    The max you can use on a regular 120v single phase supply is the 1.5Kw 110v spindle, you have to look at the whole picture as there is no such thing as 110v 3phase it is a made up spindle to sell to those that are new to this to look at your 2.2Kw spindle run on 240V NA supply then you still need a 25A supply for it to run correctly
    You are best to run a 240v 30A or 40A supply for your machine this wants to be a 4 wire cable so you can use it as 120v / 240v
    You can use a Transformer 120v to 240v you still need a 25A supply to do this, then you can use the 1.5Kw 220v Spindle
    Mactec54
    The ones saying that you can't use a 2.2kw spindle on 110 don't know what they're talking about. The cnc's vfd converts the single phase to three phase, for states. Secondly, the kw rating of spindles has nothing to do with the voltage and amperage. It's based on spindle's max RPM and kn rating. That's stated, you won't find a Spindle above 2.2kw for 110vac.
    Edit to add the following:
    220v is possible in most all modern homes (in the USA and Canada). If you have an electric dryer you already have a 220v outlet. But it might not be in a helpful place for this. If you do get a 220v line installed go with a 50 amp setup. That will ensure that you have room for a more powerful vfd/spindle pair in the future.
    Torque (lb.in) = 63,025 x Power (HP) / Speed (RPM)
    Power (HP) = Torque (lb.in) x Speed (RPM) / 63,025
    Torque (N.m) = 9.5488 x Power (kW) / Speed (RPM)
    Power (kW) = Torque (N.m) x Speed (RPM) / 9.5488
    A 2.2kw spindle at 24,000 RPM puts out 0.88n or 7.76 inch pounds of torque. That's regardless of it being 110 or 220 VAC rated spindle.
    15362
    Quote Originally Posted by FosterBDAV66 View Post
    NA is 120v not 110v
    There is always someone that pretends they know better but have never run a 2.2Kw spindle on 120v single phase to know that it is not a good option, the max spindle Kw size for 120v is 1.5Kw and lower
    Anyone that needs to use a 2.2Kw spindle will need 25A 240v NA supply
    Mactec54
  1. Replies: 0
    Last Post: 03-06-2018, 08:41 PM
  2. Where can I get attached changer for spindle 1.5kw 80mm
    By Nleo22 in forum Want To Buy...Need help!
    Last Post: 03-03-2017, 03:09 AM
  3. smal mechanical-only kit with 80mm spindle?
    By DIYedInTheWool in forum Chinese Machines
    Last Post: 10-21-2016, 10:21 PM
  4. Fitting 80mm spindle to CNC-3040
    By mixotricha in forum Chinese Machines
    Last Post: 01-16-2015, 05:58 PM
  5. 80mm Spindle Mount Sources?
    By Zuni in forum DIY CNC Router Table Machines
    Last Post: 04-06-2011, 12:00 AM
