586,075 active members*
4,186 visitors online*
    Question Cutting thin iron foil (0.05mm or 0.02mm),which laser?
    Hi All,
    I am new to this website and also new to laser cutting
    I am trying to cut a thin ironfoil (0.05mm or 0.02mm) using laser. I have been told the laser type and wavelength might effect the cutting and I have to check before getting the laser module.
    I tried to read things online but still not sure, so I hope I can get help in here.
    I found this laser module:
    https://www.ebay.co.uk/i/27406272405...EaAlNLEALw_wcB
    I am not sure the power (2.5W) is enough to cut through 0.05mm or 0.02mm iron foil and if the wavelength (450nm) will not get reflected?
    I would really appreciate any information or suggestions.
    Regards
    Re: Cutting thin iron foil (0.05mm or 0.02mm),which laser?
    I hope I can get some ideas?
    Aug 2005
    108
    You will need a fiber laser with 200W at last for good finishing, Are you sure is 0,02mm and not 0.2mm?
  1. Laser cutting/engraving aluminium foil
    By matti-laser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-10-2017, 06:09 AM
  2. JD 6090 Laser stopped cutting through thin material - help
    By Mmisterbungl in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-12-2016, 12:11 AM
  3. Need advise and help to purchase a laser for cutting thin metal
    By hive8 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-12-2015, 07:54 AM
  4. GWEIKE NEW THIN METAL LASER CUTTING MACHINE
    By Melody-gweike in forum News Announcements
    Last Post: 08-10-2012, 05:16 PM
  5. Laser Cutting Machine to Engrave thin light box LGP
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-24-2011, 04:09 AM
