586,318 active members*
3,752 visitors online*
    Jul 2020
    need help with dxf file
    need help with file.
    I am new to cad and designed a file to be cnc cut with a router and I only want it all the lines cut out not the insides so just all line art.
    this forums will not let me attach dxf files????
    Re: need help with dxf file
    Zip the file and attache the .zip file
    Dec 2013
    5717
    That is really a function of your CAM program. Normally the Trace or Engrave function is what you want to use. The actual name of the function is dependent on what CAM program you are using.
    Jim Dawson
    Sandy, Oregon, USA
