Hi, hoping you can help me. I have spent the better part of the afternoon trying to find and purchase an air pump for my Epilog Laser Cutter.
I'm the new owner of an Epilog Zing 30 Watt CO-2 machine, and also new to laser cutter. I have not yet fired up the machine, and the last thing standing in the way is acquiring an air pump for the air assist (Epilog calls it an "air curtain"). I already have an excellent vacuum fan vented and ready to go.
I spoke directly to Epilog this morning, and they said any oil-less pump will work, as long as it doesn't go over 30 PSI. They, along with others, have been recommending a basic aquarium pump. But here's my question.
The pump below is all over the internet, but in the aquarium world they apparently rate air pressure by something called "MPA." All these motors have an MPA rating of around .03, which converts to about 4.0 lbs PSI (unless the internet is doing the conversion wrong).
Is there any reason I need more than four PSI? I will be cutting mainly plastics, maybe some Acrylic, which is highly flammable, so I want the very best possible airflow for exhausting and removing the char and ash after the cut.
The one below from Boss Laser is about $170 and rated at 14 PSI output. I'd prefer to be below $100.
https://www.google.com/search?q=lase...56598992451485
Appreciate your help. If you know of a pump that fits my needs, could you please post a direct link? I'd truly appreciate it.
Thank You,
CL
