586,055 active members*
4,340 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > Setting Micro Stepping in UGS
    Mar 2017
    17
    Not sure if I'm in the right place , if wrong place moderator please move it to the proper place , thanks . I finally have my small machine running some . Old MAX NC 10 , powermax 11 steppers , currently a Arduino Uno & a CNC shield . I have my cnc shield set for half stepping , I can not find anywhere how to set half/step's in UGS . Can someone point me in the direction of where I can find instructions for setting
    1/2 stepping in UGS ?
    thanks
    animal
    Mar 2015
    410
    Re: Setting Micro Stepping in UGS
    UGS doesn't need to know this information because it gets the actual positions in mm from the grbl controller.
    All configuration is done in the grbl controller. Set the "X-axis travel resolution in steps per millimeter": parameter $100 to set the actual value.
    there is a grb WiKi where you can find information on how to use it and more.
    https://github.com/gnea/grbl/wiki
  1. How can I add a micro stepping unit?
    By jaru-eri in forum Stepper Motors / Drives
    Last Post: 07-30-2017, 07:13 PM
  2. 3 cmd-260 micro Stepping drives
    By Prolightman in forum For Sale Only
    Last Post: 09-22-2015, 07:13 PM
  3. Hobby CNC Micro Stepping Board
    By MR MOTION in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2011, 04:39 PM
  4. help with micro stepping
    By chrisw765 in forum Xylotex
    Last Post: 03-05-2005, 01:26 PM
  5. Concidering micro stepping?
    By lsfoils in forum CNC Machine Related Electronics
    Last Post: 03-27-2004, 05:36 PM
