586,069 active members*
3,484 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Hobby laser engraver...laser delay on at start of each toolpath
    Jul 2017
    348
    hi
    i have a home hobby GRBL based laser engraving machine..the machine had no issues with its original 2w diode laser..it worked fine
    i decided to add a more powerful 5.5W laser head
    i installed the new driver board and laser head and the issue is when a toolpath is started the laser fan powers on instantly at the start of all toolpaths but the laser has about a 3 second delay so i am not able to engrave anyhting due to the delay..the project never comes out correct...once the laser comes on after the delay to do a toolpath it stays on fine and completes the toolpath.....it only has issues at start of all new toolpaths due to the delay on...so if im doing a text engrave when the laser goes from letter to letter it has a delay on at the start of each letter so obviously it doesnt work ....since the machine is moving to the toolpath but the laser is delay on..
    i have swapped out with a replacement driver board and same issue i also swapped out with a replacement 5.5 laser and same issue
    im pulling my hair out trying to find out why this is happening.
    here are some pics of my hobby machine
    the small laser in the front is the orig 2w laser..it works perfectly fine..the lasrger laser in back is the 5.5w laser that for some reason has delay on
    im using same exact software LASERGRBL for both lasers....nothing has changed at all except a diff laser and driver board
    thanks
    Jul 2017
    348
    Re: Hobby laser engraver...laser delay on at start of each toolpath
    update issue fixed..it was user install error due to no instructions coming with the driver board
    in order to make new driver board work properly i had to wire driver board TTL + pin to the Arduino D11 pin
    and wire TTL- pin to Gnd pin on arduino
    now no laser on delay
  1. Home/Hobby laser engraver Laser power on delay issue when engraving need help
    By Shelby5041 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-10-2020, 04:01 PM
  2. Small hobby home laser engraver .....engraving issue ....laser turning on late
    Last Post: 09-02-2019, 11:08 PM
  3. Hobby desktop laser engraver cutter machine MT3050DIII
    By lasermornone in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-09-2015, 10:12 AM
  4. Hobby laser engraver MT3050DIII
    By mornlaser2014 in forum News Announcements
    Last Post: 08-13-2014, 11:11 AM
  5. Hobby laser engraver for sale with low price
    By RoseChina in forum News Announcements
    Last Post: 07-16-2014, 07:01 AM
