586,119 active members*
3,648 visitors online*
    Nov 2014
    14
    RFQ Water Jet or laser cut 3mm aluminum
    I'm prototyping a part and need to get a few brackets made. Basically it's ~ 1"x12", 18", 24", and 36" rectangles with nods cut into the ends. Would like to have a quick email discussion prior to sending art to ensure best use of material. Will probably need 5-10 of each length.
    Re: RFQ Water Jet or laser cut 3mm aluminum
    Over 30 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding www.plusminusthree.com Email:[email protected]
  1. Replies: 3
    Last Post: 09-10-2016, 02:13 PM
  2. Water Or Laser cut 1/4" 6061 aluminum.
    By Mlewin in forum North America RFQ's
    Last Post: 06-19-2014, 12:31 PM
  3. Water Jet Aluminum sheet
    By radiojunky in forum North America RFQ's
    Last Post: 07-13-2012, 06:40 PM
  4. RFQ - Aluminum 0.090" thick fins, Water or Laser cut
    By jhuebbe in forum RFQ (Request for Quote)
    Last Post: 05-14-2011, 07:51 PM
  5. RFQ small aluminum pieces both mill and water/laser jet parts
    By ahaidet in forum Employment Opportunity
    Last Post: 02-04-2011, 03:05 PM
