586,065 active members*
4,351 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Turret encoder only counts even number stations
Results 1 to 8 of 8
    Oct 2006
    22
    We replaced the turret encoder on out Hyundai HiT V5 lathe. It has an 8 station turret and a Fanuc 0T control. The turret motor is hydraulic.
    The machine will index to EVEN # stations just fine. Looking at X2.0 - X2.3 in control, it does show correct positioning when on an even # station.
    The bits DO NOT change to ANY ODD # stations.
    Trying to index to an ODD# station through MDI will cause an alarm of "turret too long", but the turret does indeed stop at the correct station.
    Manually indexing to an ODD station also throws same alarm.
    Any Ideas?
    Apr 2009
    1262
    Re: Turret encoder only counts even number stations
    I'd say that you have one of the turret cam switches out of adjustment or defective. You should be able to see it in the input table and determine if the switch is working or not by the same inputs. there should also be clamp unclamp inputs that should be confirmed.
    Experience is what you get just after you needed it.
    Oct 2006
    22
    Quote Originally Posted by OkumaWiz View Post
    As I said, I can see the bits turn on for even stations along with clamp /unclamp.
    The control will not acknowledge any odd positions.
    Oct 2006
    22
    I am only seeing even inputs
    X2.0-X2.3
    00000001 = 1
    00000010 = 2
    00000011 = 3
    00000100 = 4
    00000101 = 5
    00000110 = 6
    00000111 = 7
    00001000 = 8
    Aug 2015
    142
    This happens when the encoder send only "A" , or "B" ttl signal .
    Check connections , and check if encoder send A+B data corectly , i think its quadrature encoder , but u have to measure it .
    Apr 2009
    1262
    So then X2.0 is toggling on and off with each station? You are seeing the correct bit pattern, but the control will not clamp on odd stations even though you have the correct input pattern? Your description is confusing because you show the correct input pattern, but say that you can't see the odd inputs...Please clarify.
    Are you sure that when you replaced the encoder that you didn't cross any wires so that feedback is not correct?
    Oct 2006
    22
    The bit pattern i posted is what its supposed to be.
    I'm actually only getting:
    00000010 = 2
    00000100 = 4
    00000110 = 6
    00001000 = 8
    Aug 2019
    27
    Quote Originally Posted by senna95 View Post
    00000010 = 2
    00000100 = 4
    00000110 = 6
    00001000 = 8
    Try to route the cable from i/o to the turret encoder. If not see any problem. Try to replace the encoder. It definetly signal error from encoder to the i/o module.
  1. Heidenhain TNC355 ,Encoder counts / mm
    By hetlandeirik in forum Bridgeport / Hardinge Mills
    Last Post: 04-26-2019, 06:41 PM
  2. How many encoder counts/rev is too many?
    By Thomas Utley in forum Servo Motors / Drives
    Last Post: 07-17-2013, 05:15 AM
  3. Loss of encoder counts ¡ ¡
    By molocas in forum Gecko Drives
    Last Post: 01-30-2012, 03:02 PM
  4. 2000 line encoder = how many counts?
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 05-22-2007, 07:00 PM
  5. No Encoder Counts On X Axis. Y=OK
    By murphy625 in forum CamSoft Products
    Last Post: 03-09-2005, 03:20 AM
