586,071 active members*
3,915 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > VEXTA KBL Servo Series - Motor/Drive
Results 1 to 6 of 6
    Aug 2013
    32
    Exclamation VEXTA KBL Servo Series - Motor/Drive
    Hello!
    I recently bought a used VEXTA servo motor and drive, it sadly had no manual with it so i tried looking up for a manual online and i found one, but it wasn't helpful to my need
    im new to servo motors (i use stepper mostly) and i wanna know if its possible to connect my drive/motor to PC (mach3)? (the manual i found online didnt show connections to a breakout board/PC and i dont know how to connect it properly)
    ill include pictures of the motor/drive and also the manual i found online.
    if anyone has any knowledge to share about this, please do!
    many thanks.
    Dec 2013
    5717
    Re: VEXTA KBL Servo Series - Motor/Drive
    It appears that the Vextra drive will not take step & direction signals. Only analog input. Thus will not work with a standard Mach3 breakout. Mach3 has plugins for Mesa, Dynomotion, and Galil products that would run that drive.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2013
    32
    Thank you Jim for replying to me!
    If i may ask, then how can i make it work in a CNC?
    Dec 2013
    5717
    You would need a analog output motion controller connected to the drive and Mach3. Mach3 has plugins for Mesa, Dynomotion, and Galil products that would run that drive.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2013
    32
    So I can use a analog output motion controller to make it work with a CNC? And if i cant use mach3, what program can i use to make it work with the PC?
    Also do I need a manual on how to connect the drive to the analog? I tried contacting the VEXTA support team but they were of no help sadly.
    Im sorry if im asking too many questions, as i am new to the servo side!
    Dec 2013
    5717
    Quote Originally Posted by haroutkhaloian View Post
    Yes
    Dynomotion, CamSoft, Centroid, or LinuxCNC would be good choices.
    That information is in the manual you provided above. But after looking through that manual, I don't think that the VEXTA drive/motor is a good fit for a CNC machine tool axis drive, but it could be used in some special positioning applications.
    That's how we learn.
    Jim Dawson
    Sandy, Oregon, USA
  1. Replies: 28
    Last Post: 05-21-2015, 12:35 AM
  2. Help Need Info On Vexta Servo Motor
    By m.southern in forum Servo Motors / Drives
    Last Post: 10-13-2011, 04:58 PM
  3. Legacy Vexta 5 Phase Drive with new 5 phase motor
    By powerfade in forum Stepper Motors / Drives
    Last Post: 07-20-2011, 03:22 AM
  4. Vexta KBLD 120 AC Servo Drive
    By john.charles in forum Servo Motors / Drives
    Last Post: 02-07-2011, 11:29 AM
  5. servo drive for parker sm series motor
    By ihavenofish in forum Servo Motors / Drives
    Last Post: 11-10-2008, 02:42 PM
