586,630 active members*
2,716 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Resistor for unknown nema 23
    Aug 2018
    29
    is it possible to guess the resistor value for a G540 if the steppers are unknown nema 23?
    hobby machine, limited use, would I be better off just letting em run hot?
    Bob
    Aug 2005
    1100
    Re: Resistor for unknown nema 23
    Hi Bob
    If is better to run them at there rated current. If they are overdriven the excess heat can eventually damage the motor. Also you will get better speed performance by not overdriving them.
    Do the motors have any markings on them as you may be able to determine the rated current from that?
    Also what is the length of the motor body? That will determine if it is a single or double stack motor.
    The shorter single stack motors don’t usually draw more than 2.8A. So that may help.
    Consider using a set of these DB-9 breakout boards. They allow you to easily set the current without having to solder in resistors as they have an inbuilt adjustable potentiometer.
    https://www.homanndesigns.com/index....roducts_id=111
    Cheers
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    May 2005
    1662
    Buying a known set of motors would be a better bet than suboptimal performance and even possible damage. I seem to remember Gecko mentioning the resistors must be used with some motors though that may not mean possible damage to the G540 itself.
    If you measure the resistance of a motor coil it may be possible to search for a motor with the same resistance as well as length and weight. My guess is the amps will be close to the motor you have. BUT that is a guess and I'm an idiot where electrons are involved.
    Aug 2005
    1100
    You don’t need the resistors, but if they are not used, the G540 will deliver the 3.5A to the motor.
    Additionally, the drive won’t drop the current to the motor when it is idle.
    Cheers
    Peter.
  1. From NEMA 27 to NEMA 34 and voltage type selection
    By sn4k3 in forum Stepper Motors / Drives
    Last Post: 06-01-2020, 05:30 AM
  2. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  3. gecko g540 nema 23 425oz 2.8 amp need resistor
    By goorous in forum Gecko Drives
    Last Post: 09-20-2014, 09:42 PM
  4. Standard Nema 34's vs Nema 34's with encoder/controller.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-16-2006, 05:03 PM
