586,036 active members*
3,790 visitors online*
Results 1 to 8 of 8
    Jan 2015
    8
    Question CNC Router Machine - Z axis stopped working
    Hey All,
    My Z axis has stopped moving.
    Stepper controller LED turns red from green when I try to use Z axis...
    What would the most likely fault be - stepper motor dead ?
    Worked fine yesterday.
    X & Y work just fine.
    David
    Jul 2018
    6339
    Re: CNC Router Machine - Z axis stopped working
    Hi Fletch - Give all the wires a wiggle they do come loose sometimes. Then swap the motor plug to another drive if possible and see if same fault occurs. That will tell you if the motor is the issue or the driver side. After that things get complex. Peter
    Seems the motor bolt has come loose or wasn't done up right? see image
    Jan 2015
    8
    Perfect advise Pete ! I plugged it into my Y controller and it worked fine... Seems Z Microstep Driver M542-05 is faulty.
    Now to find a new one locally.,
    Thanks for your help :cheers:
    Cheers
    Dave
    May 2015
    686
    Quote Originally Posted by fletch123 View Post
    Cheers
    Dave
    Dave, if you get stuck, I have a few Longs Motors DM542A drivers here in Brisbane as I upgraded my machine to validate an engineering model a mate created. The drivers are similar spec to yours, nothing wrong with them. Send me a PM. I can ship anywhere.
    Rod Webster
    www.vehiclemods.net.au
    Jan 2015
    8
    Quote Originally Posted by rodw View Post
    Cheers Rod, I ordered a couple from China the other day, they just shipped via DHL so I shoudl have them soonish.
    Jan 2007
    626
    Cheers
    Dave
    Just be aware Dave , that all you have done is prove the Z Axis motor ISN'T faulty. You haven't actually proven the Drive is the problem.
    You might be lucky...we will see.
    More testing would be required. If you can, try swapping the control signals to the drive , ie swap Z with X or Y. Same fault or different?
    Jan 2015
    8
    Quote Originally Posted by Sterob View Post
    Thanks for your advise Sterob -
    Yep, that's exactly what I did. I swapped the control signal from the Z axis into the Y axis and it worked. Moved it back and it didn't. Fairly confident I should be set replacing the Z Microstep Driver.
    I'll post results here when the replacement unit arrives.
    Cheers
    Dave
    Jan 2015
    8
    My replacement board arrived today, 10 minutes swap over and Z axis is working perfectly again
    Cheers
    Dave
  1. Replies: 5
    Last Post: 01-25-2023, 03:11 PM
  2. Bridgeport Series 1 CNC Mill Z axis stopped working, followed by X-axis
    By Microtest in forum Bridgeport / Hardinge Mills
    Last Post: 01-13-2020, 01:25 AM
  3. Z axis just stopped working on my TB6560 board
    By Kammo in forum Stepper Motors / Drives
    Last Post: 03-31-2015, 12:08 AM
  4. HobbyCNC pro A axis stopped working
    By j2sip in forum Hobbycnc (Products)
    Last Post: 03-17-2013, 05:02 AM
