586,070 active members*
3,627 visitors online*
    Jul 2003
    1754
    making bolts unconventionally...
    A bit of math and linuxcnc... Converted little emco compact 5 cnc
    https://youtu.be/wv7mMS5xKks
    Jul 2003
    1754
    Re: making bolts unconventionally...
    Nov 2012
    1267
    Pretty cool, but Harley-Davidson might sue you for that sound starting at 3:10. :wave:
    Aug 2005
    124
    neat. whats your g code look like?
    Jul 2003
    1754
    some more cutting with slow mo...
    https://youtu.be/_S_bGAuTN0s
    The gcode currently sends the HAL layer the settings it needs. I hope to do a remap of gcode soon.
    (polygon radius)
    m68e0q.30625
    (number of sides)
    m68e1q6
    (Cutter diameter - probably get from the tool table in the future)
    m68e2q.375
    (rotate poly 0deg)
    m68e3q0
    (enable polygon component)
    m64p0
    (disable polygon component)
    m65p0
  1. Brass Bolts
    By mezalick in forum MetalWork Discussion
    Last Post: 11-07-2014, 05:45 PM
  2. Eccentric bolts
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 07-27-2014, 02:18 AM
  3. 1/2 unf bolts
    By ad1z in forum MetalWork Discussion
    Last Post: 05-29-2013, 10:55 PM
  4. Need dimensions for housing bolts (not mounting bolts)
    By rcpilot82 in forum Stepper Motors / Drives
    Last Post: 09-22-2011, 02:29 AM
  5. HSR rail bolts?
    By Gnu in forum Linear and Rotary Motion
    Last Post: 01-10-2007, 11:24 PM
