586,069 active members*
3,484 visitors online*
IndustryArena Forum > CAM Software > CamBam > Cutting pockets from sheet aluminum
Results 1 to 2 of 2
    Sep 2020
    18
    I have just started using CB and we need to cut some holes into a sheet of aluminum. I don't need a whole pocket milled out. I had been doing this by manually shrinking a profile to compensate for the cutters radius. Though this works it can be confusing and difficult. Is there an easier way? I don't think I am advanced enough in my CNC journey to set up cutter compensation, not to mention that setting up CC may be more difficult than normal as we are using a Fanuc 3M controller. Is there a way for CB to automatically mill out a inner profile?
    IMAGES: https://flic.kr/s/aHBqjzvnSg
    Thanks,
    Justin
    Sep 2020
    18
    Re: Cutting pockets from sheet aluminum
    Never mind! I got it figured out. Adding tool diameter to profile and selecting inside or outside does it. Onward!
  1. Cutting sheet aluminum to get a round piece
    By Azalin in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-02-2016, 07:20 AM
  2. Aluminum sheet cutting on router
    By Funkyjunk in forum MetalWork Discussion
    Last Post: 09-18-2010, 08:00 AM
  3. Cutting aluminum sheet
    By Smokingman in forum MetalWork Discussion
    Last Post: 06-16-2010, 05:28 PM
  4. Cutting 1/4" aluminum sheet
    By energyforce in forum MetalWork Discussion
    Last Post: 12-01-2005, 08:12 AM
  5. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
