586,076 active members*
3,893 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor changes direction when loaded
    Jan 2015
    23
    Hello I build an CNCmill two years ago and it has been working good since than until today... when the drill goes into the material and The stepper motor gets a little more load it canges direction until it the drill hits the other side than it changes direction again... if I just drives the avis with no load and keeps tapping the X+ Button then it randomly changes direction. Any ideas? Thankful for answers.
    Dec 2012
    192
    Re: Stepper motor changes direction when loaded
    Hello.
    I suggest you look for rusty connectors.
    I just had a problem where one motor didn´t change direction. It happended to be a rusty connector. I replaced the female connector and cleaned the male connector on the drive using flux as that used for electronics servicing rubbing it with a cotton swap. No problem since.
    While not exactly your problem I think it´s worth checking.
    Regards.
    Jul 2018
    6339
    Agreed sounds like a faulty connection so check all electrics. Peter
  1. Stepper Motor Only Jogs One Direction
    By jeff johnson in forum Stepper Motors / Drives
    Last Post: 06-11-2019, 03:54 PM
  2. Stepper motor direction
    By netboss in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-02-2017, 03:15 AM
  3. Stepper motor direction.
    By regpugh in forum Stepper Motors / Drives
    Last Post: 04-06-2015, 01:19 PM
  4. Stepper motor only runs in one direction
    By nevillewilliams in forum Stepper Motors / Drives
    Last Post: 03-14-2015, 06:04 AM
  5. Replies: 1
    Last Post: 04-23-2014, 10:45 PM
