586,521 active members*
3,535 visitors online*
Results 1 to 8 of 8
    Apr 2019
    6
    Help needed to identify my Mill
    Hello, I have this 1987 mill in my garage and would like to get it operational, I can't find any makers name any where.
    I has a General Numeric 810m probably a GA 1 have it powered up but need the system toolbox .
    Larry
    Dec 2013
    5717
    Re: Help needed to identify my Mill
    The base machine has the appearance of being made by Topwell, a manufacturer of high quality machine tools in Taiwan. There were many container loads of those machines imported in the 80's and then the CNC hardware was installed by the importer in the US. If you bought a container load, Topwell would put any name you wanted on it. The badge normally is above the spindle speed dial, but it looks like yours is missing. Most of the machines I have seen had Anilam controls on them, never seen one with a General before. That's a first for me. Most of those importers are long out of business, but you can still get some parts for the machines.
    As far as the controls, good luck. I wouldn't even mess with 30 year old controls, but I have a pretty low tolerance for antique controls, although I am still using the 30 year old DC servos and drives on my machine with modern controls. Modern control systems are cheap and readily available. I would look at Dynomotion, Centroid, Mesa, or CamSoft. If you should want to replace servos, then DMM servos and drives would be my first choice.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2009
    1573
    BP kneemill clone CNC.....good luck finding software. what is inside the cabinets? VFD ? Axis amps?
    Apr 2019
    6
    The cabinet has all the power supplies and the simoreg transistorsteller
    Apr 2019
    6
    Thanks Jim, I just looked at a picture of a Topwell mill and I think you are right.
    Still not sure what to do with the controls but I will,check into cost and availability in the near future.
    Thanks again
    Larry
    Apr 2009
    1379
    General Numeric was a joint marketing company between Siemens and Fanuc; the 810 is definitely a Siemens.
    Apr 2019
    6
    Thank you, I have contacted Siemens and gave them the part numer of my control.
    They said they will contact me with a P/N and cost wor what I need.
    Thanks again
    Aug 2009
    1573
    Quote Originally Posted by Lardawg View Post
    Thanks again
    ...would be nice if you can get up and running for a few hundred dollars
    good luck on the mission
  1. Help Needed: Identify controller board
    By rgfischerjr in forum Hobbycnc (Products)
    Last Post: 12-29-2020, 04:34 PM
  2. To Identify Fuse Needed. 50w Chinese Laser Cutter
    By jaymez10 in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 08-21-2017, 07:21 PM
  3. Please help me identify this mill
    By Azalin in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2017, 11:44 PM
  4. Help Identify this mill
    By Mogal in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2008, 09:28 PM
  5. can anyone identify this mill
    By jvetters in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2007, 09:15 PM
