586,103 active members*
3,382 visitors online*
Results 1 to 8 of 8
    Nov 2010
    9
    Homing with physical switches
    When i do Homing using physical switches, everything goes well except the DRO for the machine coordinates is not showing zero but it shows positive number for x and y and a negative number for the Z axis It should show zero for all 3 DRO. The AUTO ZEROS in Homing Limits are already ticked. What's wrong?
    But if I use Soft Limits to Ref All Home, the machine coordinate are all zeros for X Y and Z.
    Aug 2005
    1094
    Re: Homing with physical switches
    In the homing config in Mach3, there are entries for the X Y Z home position that the DROs will be set to when the switch is hit.
    Check their value and set them to Zero.
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
    Nov 2010
    9
    Is G28 Home location coordinates you are referring to?It's all zeros when the problem happens.
    Quote Originally Posted by phomann View Post
    Cheers
    Peter
    Dec 2012
    192
    Hello.
    It is possible that you have to do either a manual zeroing or a MOVE to coordinates <0,0,0>.
    Another possibility is as follows.
    I´m not familiar with software other than my own yet it is possible that your system is adding some takeoff distance that you have not considered. Let me explain.
    In my machines once I run the HOME sequence all the motors are driven in that direction. Every axis stops when its corresponding home sensor is hit. Once all home sensors are pressed another sequence turns the motors for a given distance away from each sensor. I named that distance as TAKEOFF. I don´t know if it´s named differently or even exists on other systems. I can preset that distance. It´s not until all axes have reached that distance that the counters are reset to zero.
    I hope this helps.
    Regards.
    Oct 2016
    10
    Quote Originally Posted by BBMNet View Post
    I think that's normally referred to as "back-off"
    All controllers have their own homing routines but it's not uncommon to approach homing sensors at speed and then slowly back-off again until the sensors are cleared to get an accurate position.
    I suspect that the configuration lazercut is looking for is in the controller configuration.
    Nov 2010
    9
    And where is this aetting hidden? Thanks
    Quote Originally Posted by hof View Post
    Oct 2016
    10
    I'm not familiar with Mach3 which I guess that you are using. Perhaps it's integrated with the other settings.
    In Mach4 it's under config > control and the configuration looks different for each controller plug-in.
    Perhaps someone with Mach3 experience can step in?
    Nov 2010
    9
    I am sure one day that setting will be discovered.
    Soft limits is good enough for now. The physical switches will double up as limit switches.
  1. Homing switches and relays.
    By TTalma in forum DIY CNC Router Table Machines
    Last Post: 03-26-2018, 06:25 PM
  2. How Good Are The Homing Switches
    By Bob La Londe in forum Tormach Personal CNC Mill
    Last Post: 03-06-2018, 08:22 PM
  3. Why do I need homing switches anyway?
    By Heizenberg in forum Chinese Machines
    Last Post: 11-06-2013, 09:15 PM
  4. homing switches
    By JPS europa in forum Shopmaster/Shoptask
    Last Post: 04-03-2013, 01:08 PM
  5. Limit switches and homing switches
    By AeroKam in forum Open Source CNC Machine Designs
    Last Post: 01-05-2008, 02:56 PM
